Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Need some electrical advice, as my days of my Electrical Engineering degree are well behind me...
I have 4 PMR446 radios ("walkie-talkies"). They work great, but when using an earpiece, every-time the internal audio amplifier fires up/down, you hear a huge THUMP noise. Connecting to a computer speaker, I see the speaker move out when firing up, and in when firing down. I can only assume that there is a DC bias in the audio signal that the people at Binatone (make of radios) haven't filtered out.
Is it possible to just filter out the DC component using a capacitor in series? If so, what one do I use? I have no idea how to work this out (anymore!). Since it's a radio, I'm not fussed on low frequencies.
share|improve this question
up vote 4 down vote accepted
I don't think horta's answer will help. From the description, this happens every time the radio starts receiving rather than just when the radio is turned on.
DC IS what you want to get rid of. A capacitor has a high resistance to low frequencies, and a coil (the speaker) has a low resistance to low frequencies.
When the amp kicks in, you get a "step" in DC voltage from zero to something less than the battery voltage of the radio. You need to block the DC. The coil itself has a high resistance to the higher frequency components of the step - that's why it is a "thump" instead of a sharper "click."
A capacitor in series with your speaker should minimize the "thump."
I would try at least 20uF. You'll need an electrolytic capacitor, so check which way the speaker output is polarized and measure how high the DC Voltage is. You'll need to observe the polarity when connecting the capacitor, and you'll need to get a capacitor rated for more DC voltage than you measure.
If you simulate the diagram, you will find that it reduces the "thump" to just a few millivolts.
I've added a simulation of an audio signal feeding the LC circuit in the diagramm. The audio is 3 dB down at 300Hz, which is where I was shooting for. There's a 40dB hump at 500Hz which I didn't expect. Less than 20uF would push the hump up higher as well as the cutoff. You'll probably want to go higher than 20uF.
share|improve this answer
20uF is way too much, especially for a walkie talkie. I'd start from 1uF, that's pretty standard for audio DC decoupling, up to 10uF if necessary (I don't think so). ofc, the bigger the better, but there's a limit to it too I guess. – Vladimir Cravero Aug 8 '14 at 16:04
20uf is just a WAG assuming that the speaker is 32Ohm, which is typical for an earphone. At a wag, that cutoff should be below 300 Hz. Two way radio filters out everything below 300, anyway. – JRE Aug 8 '14 at 16:10
what does WAG stand for? – Vladimir Cravero Aug 8 '14 at 16:59
A WAG is a Wild Ass Guess – JRE Aug 8 '14 at 18:39
One step below a SWAG, which is a Systematic WAG – Scott Seidman Aug 8 '14 at 20:21
discard
