Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have a bunch of green LEDs (not super bright), the plastic around the actual LED is physically green, but they did not come with a turn on voltage. 3V seems to work but they're not too bright, is there any way I can figure it out? What's the standard turn-on voltage for non super bright green LEDs?
share|improve this question
up vote 12 down vote accepted
A good way to think about an LED is as a variable resistance (or impedances, more commonly). At very low voltages, it has very high impedance, so not a lot of current will flow through the device. If you have a current source, as davr suggests, the current flowing through the LED times the impedance will create a voltage (Ohm's law). If you force enough current, the voltage will quickly rise and the impedance will drop. The point where current seems to flow easily is past the "turn-on" voltage you speak of. Past this point the impedance of the device is very low and large changes in current will create small changes in voltage.
I know this can still be confusing, but I would suggest staring at an I-V curve for a while (current plotted versus voltage). This is a simple looking chart but is in fact quite complex. The thing that I did not grasp until much further into my career is that the instantaneous slope of the line is actually the impedance. Once you grasp that concept, what I said earlier may become clearer.
Simple IV Curve
share|improve this answer
Brightness depends mostly on current, not on voltage. As long as you've got the correct voltage, you can adjust brightness by changing how much current the LED is given. If you have a set voltage, then changing the resistor will give you different currents. Google for "LED calculator" to see how to find the correct values.
The term you are looking for is "Forward voltage", here is a chart of some common values.
And because what davr says it true, never drive an led from a constant voltage source ( without a current limiting resistor ) – russ_hensel Dec 23 '09 at 1:53
Like davr says, LED brightness depends on current, not voltage. What nominal or maximum current is can't be found out experimentally; that's information you need a datasheet for. A higher current will increase brightness, but if it's too high it may (considerably) decrease the LED's life.
Non-super bright LEDs are often rated for 20mA, so select the series resistor accordingly. How do you do this for a LED whose specs are missing? Place a 100\$\Omega\$ test resistor in series with the LED and vary the voltage until the voltage drop over the resistor is 2V (\$\frac{2V}{100\Omega}=20mA\$). Now measure the voltage across the LED. Let's assume this is 2V, and also that the power supply for your circuit is 5V. Then
\$ R = \dfrac{5V - 2V}{20mA} = 150\Omega \$
As the others have said before, plotting and IV curve would give you all the answers.
What I could add to the discussion is that 3V is a bit too large for a green LED. Since the plastic is green (for light dispersion and... marketing reasons) and even at 3V they're rather dim as you mentioned, I think these might be 12V LEDs for automotive purposes. I've seen these at some resellers. They have a build in resistor, which allows them to operate at 12-15V as found in a car when running. They are usually used as dashboard lights and such.
discard
