Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I know the symbol at the bottom is ground, but I can't get what the other symbol is. It can be a single symbol of two arrows pointing at each other, or two symbols each one a arrow.
I also have the PCB for this schematic. It is nothing but two traces (1mm long) with a little gap in between. Is it a RF filter of some sort?
share|improve this question
up vote 15 down vote accepted
This looks like a spark gap.
(You could also look up gas discharge tube (GDT), which is similar to spark gap.)
The likely purpose of this component in your circuit is to protect the rest of the circuit from lightning strike and/or ESD. Spark gaps are often the fist line of defense against high voltage.
Advantages of spark gaps. Once the arc is established, a spark gap acts as a crowbar, and it can dissipate a lot of energy. Because of that, spark gaps are used for protection against high voltage high energy threats (lightning, defibrillator). The parasitic capacitance of a spark gap is low, so it doesn't affect the signal. A spark gap can be formed as a PCB feature for free; it doesn't require an additional component in a BOM.
Weaknesses of spark gaps. They fire at a high voltage: hundreds of volts. Also the firing voltage is not well reproducible or predictable. To address this weakness, there's usually another overvoltage protection device (such as TVS) in parallel with a spark gap. This additional device clamps at a lower voltage.
related:
What is this component and what is its use?
http://electronics.stackexchange.com/a/28959/7036
EEVblog #678 - What is a PCB Spark Gap?
share|improve this answer
Exactly my thought. – TDHofstetter Aug 15 '14 at 3:46
discard
