Tell me more ×
Hi I want my circuit to be able to switch on and off several 230V AC circuits. I was wondering if relays are my only option. It starts to get a bit expensive if you need a few. Originally I was going to use a 5V dc relay to switch the devices on and off
share|improve this question
Similar to a relay but typically for higher power/current is a contactor en.wikipedia.org/wiki/Contactor – kenny Apr 4 '11 at 17:13
I asked a similar question here: electronics.stackexchange.com/questions/16872/… - What would be the most suitable components to replace some relays? – m.Alin Sep 6 '11 at 17:49
up vote 5 down vote accepted
You may find relays with a 12 or 24V coil cheaper. You may consider triacs (thyristors) but it is hard to beat the price (and simplicity) of a relay.
share|improve this answer
@Ageis, using a higher than 5V coil will mean using a transistor to switch the relay. Also relays are isolated between the contacts and the coil, but triacs are not in themselves isolated so you need a layer of isolation such as an auxillary opto triac or opto isolator. Depending on the load you are driving, relays may be more reliable. – Martin Apr 4 '11 at 16:08
It it's being driven from microcontroller, he would need extra transistors anyway... – BarsMonster Apr 4 '11 at 16:14
@jpc Do DC relays give you enough voltage isolation to be safe? – kenny Apr 4 '11 at 17:13
@kenny, easily. Look for a relay with safety agency approvals. A quick search found this one with 4 kilovolts of isolation between coil and contacts. – Martin Apr 4 '11 at 19:43
@kenny Why DC relays? The OP is explicitly asking for AC. Maybe add a new question about relays for switching DC loads with high isolation voltage. – jpc Apr 4 '11 at 21:00
show 4 more comments
If you need fast switching (up to 50-60Hz), you can take a look at solid state relays. They don't produce a "click" like mechanical ones, but this feature comes with a price...
I just purchased several SPDT 5V relays from SparkFun the other day, and they're working very well for me. They're rated for a maximum of 5A at 250VAC or 30VDC and only cost $1.95/relay.
5V relay
If the devices you're switching are pulling more than 5A, they also have 30A SPST relays for $4 each.
I'm afraid there are few other options than relays, esp. if you want electrical insulation between your circuit and the 230V side.
You don't give details about the kind of load you want to switch, but the cheapest >2A electromechanical relay I found at Digikey is the Omron G5T, which sells for USD 1.27 quantity one. This can switch 5A @ 250V AC, but you may have to derate it if your load is reactive (capacitive or inductive).
A solid state relay (SSR) is an alternative, but SSR modules tend to be expensive. For low currents (~1A) there are affordable SSRs, however, this one costs USD 1.38. An SSR for minimum 5A will already cost you three times as much, so there the electromechanical relay is pretty much the cheapest solution.
Keep in mind that for both electromechanical and solid state relays a few extra components are required, but they won't cost that much.
By far, the most common silicon device to drive AC loads connected to mains voltage is the triac, according to ST app note AN3169,
Even including the other things required to get it to work reliably (typically an optoisolator and a RC snubber), the total parts cost is usually less than a relay.
Alas, getting it to work reliably is complicated. If you're going to use less than 20 of the things, I'd stick with easy-to-use solid-state relays (the easy-to-use package usually includes a triac plus those other things I mentioned) or an easy-to-use mechanical relay -- it's not worth tearing your hair out to save a couple of bucks :-).
discard
