So I am just getting started developing with an Altera Cyclone II EP265 mini board, and I am having some trouble getting a program that outputs the "and" and "or" of three inputs working.
The full Quartus II project is located here.
And here is the verilog code I'm using:
module Logic
//Inputs
in_1,
in_2,
in_3,
//Outputs
out_1,
out_2
//Port definitions
input in_1;
input in_2;
input in_3;
output out_1;
output out_2;
assign out_1 = in_1 & in_2 & in_3;
assign out_2 = in_1 | in_2 | in_3;
endmodule
When I upload this to the board, the three onboard LEDs are always set to high, as well as the two output pins I specified in the pin planner. I tried moving the outputs to one of the unspecified pins, and this output was low.
The steps I am doing to upload this are: Open Quartus II > Tools > Programmer > Connect USB blaster > Specify blaster in hardware settings > Run.
Can anyone see why this is not working correctly?
EDIT: Compilation messages:
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Processing started: Fri Aug 15 15:09:30 2014
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off BasicLogic -c BasicLogic
Warning (20028): Parallel compilation is not licensed and has been disabled
Info (12021): Found 1 design units, including 1 entities, in source file logic.v
Info (12023): Found entity 1: Logic
Info (12021): Found 1 design units, including 1 entities, in source file BasicLogic.bdf
Info (12023): Found entity 1: BasicLogic
Info (12127): Elaborating entity "BasicLogic" for the top level hierarchy
Info (12128): Elaborating entity "Logic" for hierarchy "Logic:inst"
Info (16010): Generating hard_block partition "hard_block:auto_generated_inst"
Info (16011): Adding 0 node(s), including 0 DDIO, 0 PLL, 0 transceiver and 0 LCELL
Info (21057): Implemented 7 device resources after synthesis - the final resource count might be different
Info (21058): Implemented 3 input pins
Info (21059): Implemented 2 output pins
Info (21061): Implemented 2 logic cells
Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 1 warning
Info: Peak virtual memory: 607 megabytes
Info: Processing ended: Fri Aug 15 15:09:32 2014
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:01
Info: Running Quartus II 64-Bit Fitter
Info: Processing started: Fri Aug 15 15:09:33 2014
Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off BasicLogic -c BasicLogic
Info: qfit2_default_script.tcl version: #1
Info: Project = BasicLogic
Info: Revision = BasicLogic
Info (119006): Selected device EP2C5T144C8 for design "BasicLogic"
Info (21077): Low junction temperature is 0 degrees C
Info (21077): High junction temperature is 85 degrees C
Info (171003): Fitter is performing an Auto Fit compilation, which may decrease Fitter effort to reduce compilation time
Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature.
Info (176444): Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices
Info (176445): Device EP2C5T144I8 is compatible
Info (176445): Device EP2C8T144C8 is compatible
Info (176445): Device EP2C8T144I8 is compatible
Info (169124): Fitter converted 3 user pins into dedicated programming pins
Info (169125): Pin ~ASDO~ is reserved at location 1
Info (169125): Pin ~nCSO~ is reserved at location 2
Info (169125): Pin ~LVDS41p/nCEO~ is reserved at location 76
Critical Warning (332012): Synopsys Design Constraints File file not found: 'BasicLogic.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
Info (332144): No user constrained base clocks found in the design
Info (332096): The command derive_clocks did not find any clocks to derive. No clocks were created or changed.
Warning (332068): No clocks defined in design.
Info (332130): Timing requirements not specified -- quality metrics such as performance may be sacrificed to reduce compilation time.
Info (176233): Starting register packing
Info (176235): Finished register packing
Extra Info (176219): No registers were packed into other blocks
Info (171121): Fitter preparation operations ending: elapsed time is 00:00:00
Info (170189): Fitter placement preparation operations beginning
Info (170190): Fitter placement preparation operations ending: elapsed time is 00:00:00
Info (170191): Fitter placement operations beginning
Info (170137): Fitter placement was successful
Info (170192): Fitter placement operations ending: elapsed time is 00:00:00
Info (170193): Fitter routing operations beginning
Info (170195): Router estimated average interconnect usage is 0% of the available device resources
Info (170196): Router estimated peak interconnect usage is 0% of the available device resources in the region that extends from location X0_Y0 to location X13_Y14
Info (170194): Fitter routing operations ending: elapsed time is 00:00:00
Info (170199): The Fitter performed an Auto Fit compilation. Optimizations were skipped to reduce compilation time.
Info (170201): Optimizations that may affect the design's routability were skipped
Info (170200): Optimizations that may affect the design's timing were skipped
Info (11888): Total time spent on timing analysis during the Fitter is 0.16 seconds.
Info (306004): Started post-fitting delay annotation
Warning (306006): Found 2 output pins without output pin load capacitance assignment
Info (306007): Pin "4" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info (306007): Pin "5" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info (306005): Delay annotation completed successfully
Info (11218): Fitter post-fit operations ending: elapsed time is 00:00:00
Warning (169174): The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
Info (144001): Generated suppressed messages file /media/alex/Data/Verilog/BasicLogic/output_files/BasicLogic.fit.smsg
Info: Quartus II 64-Bit Fitter was successful. 0 errors, 6 warnings
Info: Peak virtual memory: 639 megabytes
Info: Processing ended: Fri Aug 15 15:09:36 2014
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:02
Info: Running Quartus II 64-Bit Assembler
Info: Processing started: Fri Aug 15 15:09:38 2014
Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off BasicLogic -c BasicLogic
Info (115031): Writing out detailed assembly data for power analysis
Info (115030): Assembler is generating device programming files
Info: Quartus II 64-Bit Assembler was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 541 megabytes
Info: Processing ended: Fri Aug 15 15:09:39 2014
Info: Elapsed time: 00:00:01
Info (293026): Skipped module PowerPlay Power Analyzer due to the assignment FLOW_ENABLE_POWER_ANALYZER
Info: Running Quartus II 64-Bit TimeQuest Timing Analyzer
Info: Processing started: Fri Aug 15 15:09:41 2014
Info: Command: quartus_sta BasicLogic -c BasicLogic
Info: qsta_default_script.tcl version: #1
Info (332142): No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
Info: Found TIMEQUEST_REPORT_SCRIPT_INCLUDE_DEFAULT_ANALYSIS = ON
Info (332159): No clocks to report
Info: Analyzing Slow Model
Info (332140): No fmax paths to report
Info (332140): No Setup paths to report
Info (332140): No Hold paths to report
Info (332140): No Recovery paths to report
Info (332140): No Removal paths to report
Info (332140): No Minimum Pulse Width paths to report
Info (332001): The selected device family is not supported by the report_metastability command.
Info: Analyzing Fast Model
Info (332102): Design is not fully constrained for setup requirements
Info (332102): Design is not fully constrained for hold requirements
Info: Quartus II 64-Bit TimeQuest Timing Analyzer was successful. 0 errors, 4 warnings
Info: Peak virtual memory: 497 megabytes
Info: Processing ended: Fri Aug 15 15:09:42 2014
Info: Running Quartus II 64-Bit EDA Netlist Writer
Info: Processing started: Fri Aug 15 15:09:44 2014
Info: Command: quartus_eda --read_settings_files=off --write_settings_files=off BasicLogic -c BasicLogic
Info (204026): Generated files "BasicLogic.vo", "BasicLogic_fast.vo", "BasicLogic_v.sdo" and "BasicLogic_v_fast.sdo" in directory "/media/alex/Data/Verilog/BasicLogic/simulation/modelsim/" for EDA simulation tool
Info: Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 799 megabytes
Info: Processing ended: Fri Aug 15 15:09:45 2014
Info (293000): Quartus II Full Compilation was successful. 0 errors, 11 warnings
EDIT 2: Report after analysis and elaboration (some possible solutions here):
Info: Running Quartus II 64-Bit Analysis & Elaboration
Info: Processing started: Mon Aug 18 08:30:16 2014
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off BasicLogic -c BasicLogic --analysis_and_elaboration
Warning (12019): Can't analyze file -- file BasicLogic.v is missing
Warning (12125): Using design file BasicLogic.bdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
Info: Quartus II 64-Bit Analysis & Elaboration was successful. 0 errors, 3 warnings
Info: Peak virtual memory: 867 megabytes
Info: Processing ended: Mon Aug 18 08:30:17 2014
