Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm working on a project the will use 20 white 3mm LEDs that I harvested from a 154 LED Christmas light string. I plan to use a 9 volt battery for power. What's the optimal wiring schematic? Series, parallel, or a combination? What type of resistor will work?
share|improve this question
What color LEDs do you have? That makes a very big difference. – TDHofstetter Aug 19 '14 at 19:34
A little 9V transistor battery? How long do you want the LED's to be on for? Is something like a few hours OK? – George Herold Aug 19 '14 at 19:39
Updates question with LED color. – DataZombies Aug 19 '14 at 20:39
Using white LEDs you'll probably find their forward voltage to be around 3 to 3.4 V each. Thus you will have to have ten sets of two in series. The approach and math in my answer is still applicable, but modify it as necessary for your LEDs. Good luck. – JYelton Aug 19 '14 at 21:06
up vote 12 down vote accepted
Do you know the \$V_f\$ (forward voltage drop) of your LEDs? This is the value you need to know in order to calculate everything else.
Fortunately you can determine it by measuring. Connect an LED in series with a 330 ohm resistor (or 470 or 1k, whatever is handy in this range) and your multimeter in current measurement mode. Apply 9V and note the current.
Let's say you used a 330 ohm resistor and measured 20mA. This would mean the resistor has 0.20mA * 330Ω = 6.6V across it. That leaves 2.4 for the LED.
(This is a convenient made-up number, because many LEDs have a forward current of 20mA. If you measure more or less, you should change values until you get closer to 20mA or whatever the typical forward current of your LED is. If you don't know, you are probably safe assuming 20mA.)
Knowing this, you can divide 9 by the now-known \$V_f\$ of the LED: \$\frac{9}{2.4} = 3.75\$. Since you can't have partial LEDs, you can connect three LEDs in series, meaning you would have six runs of three and one run of two for a total of 20 LEDs. A current-limiting resistor would be needed on each series run.
To calculate those, again just use Ohm's law. Three LEDs with a \$V_f\$ of 2.4 gives a total voltage drop of 7.2. Subtract that from 9 to get the voltage drop on the current-limiting resistor. To have 20mA in the series, we can calcuate the resistor value (V/I) as \$\frac{1.6V}{0.02A}=80\Omega\$.
For the series run with just two LEDs: Two LEDs at 2.4V is 4.8V, subtracted from 9 is 4.2. The resistor then is \$\frac{4.2V}{0.02A}=210\Omega\$.
Now, all of these numbers are made-up, but it should give you the means to calculate them for your actual components.
Here is a schematic for this series-parallel circuit:
Note that 80 and 210 ohm values are "ideal" and using the commonly available 100 and 220 ohm values (respectively) would be just fine.
Edit:
Each run of series-connected LEDs will draw 20mA (again, assuming that's the typical \$I_f\$ of the LEDs you are using). With seven such branches, the total current should be about 140mA.
A typical 9V battery has approximately a 500 mAh capacity with a 100 mA discharge, so I would expect no more than 3.5 hours run time (\$\frac{500}{140}\$) with a fresh alkaline battery.
share|improve this answer
discard
