Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm a total newbie fooling around with a project of mine.
I want to use a MCP23071 I2C port extender (Data sheet) for my arduino project.
The chip has three hardware pins that must be externally biased.
Now, I apologize if the question is silly, but can I just connect the pins to V+ or GND, or do I need to put a resistor in series to limit the current? I looked around a bit but I wasn't able to find an answer.
share|improve this question
Don't forget the reset pin as well as the three address lines, looks like that should be tied high as well. – PeterJ Aug 24 '14 at 11:40
yup, good catch :) thanks, and thanks for fixing the link, too! – garph0 Aug 24 '14 at 11:51
up vote 3 down vote accepted
Yes you can directly connect these pins to GND or V+.
The reason you did not find this explicitly stated is that it is standard that a high-impedance digital input can be connected directly to a logical 0 or 1. When a resistor was needed this would be stated explicitly.
Using a resistor instead of a hard connection might be convenient when you need to change the address on a finished PCB: you can short the pin to the opposite supply rail without damaging anything.
share|improve this answer
discard
