Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have been messing around with a basic FM transmitter circuit, and I want to have a better explanation on how it works. I have searched around and found nothing. Can someone please explain how the LC circuit inside of this circuit can continue to oscillate? Also, what would be the function of capacitor C3?
share|improve this question
up vote 7 down vote accepted
C3 turns the circuit into an oscillator. To understand this you need to think hard about the role of the emitter and the thing you have to think hard about is this - the emitter (as well as the base) is an input to the transistor that is amplified by the transistor.
An ac voltage (superimposed on a dc voltage) between base and emitter is amplified by transistor action - people usually talk about an ac voltage applied to the base being amplified by the transistor but, in reality the base current is due to a voltage difference of about 0.7 volts between base and emitter. If the signal on the base (or emitter) alters the base current then the transistor will amplify it it.
If you held the emitter voltage constant and raised the base voltage there would be an increase in base current that would cause a greater collector current. If you held the base voltage constant and increased the emitter voltage there would be a decrease in collector current.
So when base voltage increases, collector current increases and there is a tendency for collector voltage to drop - i.e. the voltage on the collector is inverted compared to the base BUT it's not inverted when you raise the emitter voltage - collector voltage (signals) are non-inverted (and amplified) versions of the signal on the emitter - this means that C3 creates positive feedback and, positive feedback (in this type of circuit) creates an oscillator.
The modulation is a little subtler - there is always a few picofarads capacitance between collector and base and this capacitance gets smaller as the collector-base junction gets more reverse biased. This means you can tune the oscillator a bit by raising or lowering the base voltage - the microphone does this with the audio signal it produces and the CB capacitance is modulated at the same rate as the signal from the microphone. This undulating CB capacitance is, effectively in parallel with C2 and bingo, you get FM (plus a little bit of AM too.
share|improve this answer
Does the value of C3 really matter as long as it is a reasonable value? Or does it somewhat determine the frequency? Thanks again. – Sock314 Aug 25 '14 at 22:55
@Sock314 - it slightly determines the frequency - there is a non zero degrees phase shift thru C3 to the emitter and this causes the oscillator tank circuit to not quite run at the theoretical tank frequency. The bigger you make C3 the closer to zero phase shift you get but the more you load the output and too big a value for C3 and the oscillator stops. – Andy aka Aug 26 '14 at 7:18
discard
