Here's the problem: I carry around two devices, but at different power requirements - one at 20V/3.5A and the other at 12V/3.5A. I'd like to only carry around one power brick and just carry an adapter cord.
I've looked around everywhere for universal power supplies, but the only one I found that included both 12V and 20V was at 5A. I don't want to risk damaging my batttery at the higher amps.
So now I'm looking to an engineering solution. I have a basic understanding of electrical engineering, but I'm having a little trouble here figuring out what I'll need.
From my research, I believe I can use a 20V/3.5A power supply and a 12V step down voltage regulator. The problem is I can't find any voltage regulators at the correct amps - either too low at like 600 mA or way to high at 20A. Does anyone know where or how I can find the part I'll need?
I assume, using the pinout diagram, I can essentially just run the power from the 20V power supply thru the voltage regulator and come out with 12V. Am I missing anything?
And if anyone has a better solution, I'm all ears (or eyes).
