Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
When a datasheet mentions the output impedance of a pin so and so ohms. What exactly does it mean? Can anybody explain through a diagram how does it look like?
share|improve this question
An output pin looks something like this:
Vout is an ideal voltage source, R is the output resistance of the source and C is the output capacitance of the pin.
Let's ignore the cap for now.
An ideal output pin would include the voltage source only, but unfortunately we're unable to build voltage sources with zero internal resistance, so when you actually make a voltage source it will have a series resistor which value is the "internal impedance" of the source. If your voltage source is used to drive a pin then that same R is also called the "pin output resistance", i.e. the resistance that you measure between out and reference with all the sources turned off. The output resistance is an important parameter because it limits the load resistance that you can connect to the pin: if you have some \$1k\Omega\$ output resistance and you want do drive a \$1\Omega\$ load you will have a bad time, since the output voltage will almost not vary because of the voltage divider you are de facto building.
So what's this C about? That's another parasitic component, it comes from traces on the Silicon die, parasitic transistors capacitance and so on. The capacitor is important because it limits the speed of your pin, so it's a dynamic parameter, while the output resistance is a static one. As you can see the RC components form a first order low pass filter: the higher the C, the lower the corner frequency \$f_C=\dfrac{1}{2\pi R C}\$, the lower the maximum speed you can toggle your pin while keeping a clean wave.
I added the C part since you speak of the output impedance, that should include the capacitor. What you find in datasheets is usually the output resistance (\$\Omega\$) and the output capacitance (F) as separate values.
share|improve this answer
+1, but you should correct from "impedance" to "resistance" in the very first phrase. – Mario Vernari Aug 29 '14 at 9:38
@Mario: why? impedance is a good term in this context. – Wouter van Ooijen Aug 29 '14 at 9:43
I second @WoutervanOoijen, impedance is generic thus correct. – Vladimir Cravero Aug 29 '14 at 9:50
IMHO, if you simplify the description of the meaning (which is what the original question asked) you should down the equivalent circuit to simple R and C (L as well, if you want). If you mean to represent with the R-symbol the whole resistance of the output, then why did you add a C? I only believe the reader would be confused: either simplify considering just the real-component, or create a complete schematic (although I prefer to explain in the simplest way). – Mario Vernari Aug 29 '14 at 10:15
@MarioVernari it seems pretty clear to me why there is the cap, where it comes from and why I included it. And it is ignored in the first part of the answer... – Vladimir Cravero Aug 29 '14 at 10:26
Simplified, its just the internal resistance of the output. An equivalent circuit would be just a resistor in series with the sourcing output pin.
Any non-ideal source has some (parasitic/unwanted) internal resistance due to the physical layout of the source. In general it needs to be low compared to the load, because with increasing current, the voltage drop on the internal resistance increases and thus, the output voltage decreases.
I keep talking about resistance but you asked about output impedance.
Impedance = resistance + reactance
Reactance is the opposition of a circuit element to a change of electric current or voltage, due to its inductance or capacitance. Since the output behavior is not entirely resistive, we talk about "output impedance".
When you wrote "... in general it is very low compared to the load", did you mean to write "... in general it needs to be low compared to the load"? – gbulmer Aug 29 '14 at 9:37
@gbulmer: Yes, that would be a better way to express it. Thanks, I clarified it. – Rev1.0 Aug 29 '14 at 9:37
It might be better to say that |Impedance| = \$\sqrt{|resistance|^2 + |reactance|^2}\$. What you wrote is not wrong if you're adding reactance as an imaginary number, but it might be confusing to some. – Spehro Pefhany Aug 29 '14 at 13:04
Yes Spehro.. But in this conrext it is pretty obvious and understood. – Durgaprasad Aug 29 '14 at 14:12
@SpehroPefhany: Thanks for pointing that out, but I intentionally used the words instead of symbols to keep it simple. Its just meant to point out that impedance is not the same as resistance - strictly speaking. – Rev1.0 Aug 29 '14 at 14:43
I fear that the answer is not as simple as one might like, but here it is. I'll offer the technically correct answer first, then give a more comprehensible approximation.
In the jargon as you may know, output impedance is a complex, frequency-domain quantity; whereas output resistance is a real quantity, whether constant or variable over time. Notwithstanding, both impedance and resistance are measured in ohms and, colloquially, the two words are often used as synonyms. So much for the terminology.
If \$V(t)\$ and \$I(t)\$ are respectively the voltage on the pin (usually as defined with respect to GND ground) and the current flowing out of the pin, then the output resistance is $$R(t) = \frac{dV}{dI} = \frac{dV/dt}{dI/dt}.$$ Most likely in your context, output impedance means the same. However, according to the formally accepted definition, the output impedance is $$\mathbf{Z}(f) = \frac{\mathbf{V}(f)}{\mathbf{I}(f)},$$ in which the \$f\$ represents frequency and the \$\mathbf{Z}(f)\$, \$\mathbf{V}(f)\$ and \$\mathbf{I}(f)\$ are complex, frequency-domain quantities.
Does that make sense? No? No, I agree: it does not make sense, unless you have had your brain warped by the likes of an electrical or mechanical engineering degree. So here is the easy version (which is still hard enough): Suppose a pin with an output impedance of 100 ohms. Suppose also that this pin is supplying 3 milliamps to whatever device you have connected to the pin. Now suppose that your device starts demanding 5 milliamps through the pin, an increase of 2 milliamps. In this case, the voltage on the pin will drop by (100 ohms)(2 milliamps) = 0.2 volts.
If that's too much of a drop, if you wanted your voltage to remain steadier than that, then you need a chip whose relevant pin is characterized by a lower output impedance.
Does that make sense? Still no? Then here it is: output impedance quantifies the ability of a microchip or other piece of electronics/electrics to supply electric current on demand. The electrical outlet on your wall is good at supplying current, and its output impedance is low. A paper clip held in my hand is poor at supplying current, and its output impedance is high. If you draw more current from a microchip, piece of electronics or electrical outlet than it is designed to supply, if you overload it, then its voltage must start dropping, in protest as it were; just as if you burden the end of a cantilevered beam too heavily, if you overload it, it must flex and its end must start drooping, in protest as it were. In this sense, a pin with low output impedance is like a sturdy beam: it holds up under load.
There is admittedly rather more to it than this. For example, in an instrumentation current loop, output admittance instead plays the role described, which is confusing. Also, fuses and circuit breakers will often cut off the current entirely when too much is demanded, which seems like it would have something to do with your question but really does not. But so much will do to go on with, and should give you a general feel for the problem.
Whatever you have said here everything is correct.but why did you have to make it so complex? – Durgaprasad Aug 29 '14 at 16:35
Well, because you know how it is: other users of the site with electrical engineering degrees might give me grief if it looked as though I did not know the definition technically accepted among engineers, which I do happen to know. Personally, I agree with you: the simpler answer in the second half of my post is the one you want, and (if truth be told) is probably how engineers usually think about it. The technical definition is for proving theorems regarding maximum power transfer and the like, not usually for practical use. – thb Aug 29 '14 at 16:41
I find that the wording of the question is often a good indicator of how in-depth the OP is looking to get. Some askers are beginner hobbyists in their teens, others have a degree in electrical engineering. While someone finding the answer via Google might appreciate the detail, for the OP it may well be incomprehensible. If you're dipping into TeX math, it's like talking Greek to them - often literally. – Rennex Sep 3 '14 at 2:16
Let me start by saying that an output pin (or input pin), by itself, has no impedance. If this was already clear to you, then you know that it has to be between two pins. It just so happens that the other "pin" is ground. So whenever the impedance of a pin is mentioned, it is commonly known/understood that it is with respect to ground.
What the "impedance specification" means, is simply, if you were to take an impedance measurement of the pin to ground, you would obtain the value given. However, since impedance depends on the frequency used to determine its value, a frequency must also be specified. If a frequency is not specified, then they are referring only to its resistance and this is the value you obtain if you connect an ohmmeter between the pin and ground.
The diagram provided by Vladimir is the exact model.
discard
