I have seen several PCB that they have wide holes in some their parts (especially the supply of circuits parts). for example take a look at this picture:
figure1
and on the board:
figure2
  1. Not sure but I think it is related to the noise, Is it correct?
  2. If so, it's not acceptable to me because other parts of PCBs aren't conductive then how it can transfer the noise?
  3. If so, how much it can be effective?
  4. And my last question is, do they have any special name?
    \$\begingroup\$ 1. It's for voltage isolation. 2. Unrelated, because it's not noise. 3. Very. Air is a much better insulator, and it doesn't get wet/have a conductive film form. 4. Isolation slots. \$\endgroup\$ Oct 23, 2014 at 8:16
  • \$\begingroup\$ @helloworld922 Thanks for helpful link. \$\endgroup\$
    – Roh
    Oct 23, 2014 at 8:23
  1. It's for better high-voltage safety.
  3. Very. Air is a much better insulator, and it doesn't get wet/have a conductive film form. Basically, a circuit board can get dirty and/or wet. This makes the surface of the board slightly conductive, and once it's a bit conductive, electrochemical action can make it very conductive, and then you get a free fire.
  4. Isolation slots / creepage distance cutouts/air gaps.
