Is there any way to make a switch that uses a 5V input to open a -5V or 10V connection? (so i can switch between making a line -5 and 10V).
Thanks in advance!
Is there any way to make a switch that uses a 5V input to open a -5V or 10V connection? (so i can switch between making a line -5 and 10V). Thanks in advance! |
Some switches like ADG733 have a separate Vss pin which can be at a lower potential than the logic GND; this means you could have a -10V supply on the Vss pin which would allow the gate to control up to a -10V signal whilst still having a 0-Vdd logic input. Unfortunately the ADG733 is limited to a 5.5V supply; but there are probably other parts that will do the same job (numbers escape me at the moment.) |
I'm not sure if you're asking for an analogue switch that can handle signals in the range -5V to +10V or a digital interface to convert a 0 to 5V level into a -5v to +10V level. If it is the latter, my answer to this question might help. This arrangement would work with N & P channel FETs with little modification. |
