Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
When wiring speakers to a 100W consumer-grade amplifier, how do I select an appropriate gauge cable (for 8-ohm speakers)?
Also, if 14 gauge cable is sufficient, what harm is there in using a heavier cable such as 12 or 10 (other than inconvenience and cost)?
Related: Whats the best cable to transfer audio signal?
Semi-related: Any truth behind "multipole" technology in audio signal transmission?
share|improve this question
up vote 10 down vote accepted
The #1 issue with speaker cables is that they have a fixed resistance, and the speaker has a impedance that varies with frequency. (Note: you can almost use the terms resistance and impedance interchangeably in this context.) When you combine the wires resistance with the speakers impedance you'll get, basically, a voltage divider. The net effect of this is that the resistance of the wire will change the frequency response of the speaker.
Here's a graph that shows the speaker impedance and frequency response. Notice that the average impedance is 8 ohms, but really varies between 4 and 33 ohms. Now, let's say that your wire has a resistance of 10 ohms (that's super high, but I'm illustrating a point). At 500 Hz the speaker has a 5 ohm impedance. This effectively makes a voltage divider that cuts the power going to the speaker by 5:15, or 1:3. So if the amp is spitting out 100 watts, only 33 watts is making it to the speaker. But at 2 KHz the speaker impedance is about 30 ohms. That means that the voltage divider is more like 30:40, or 75 watts from the 100 watt amp output is making it to the speaker.
The end result of this is that the higher the resistance of the cable, the more the frequency response of the cable is going to be affected. When you size the gauge of the cable to minimize this resistance, odds are that the cable is going to work fine for whatever current you actually need to move-- unless you're doing pro-audio and have several kilowatt amps.
A really rough rule of thumb is that you want the cable resistance to be less than 10% of the nominal speaker impedance. So for an 8 ohm speaker you'd want less than 0.8 ohms in the cable. Of course, if you want to know for sure then you have to look up the impedance graph on the speaker and start calculating.
When this is all distilled down, you'll find that 16 gauge wire works for most home applications unless you have your amp a long way from the speakers (which you shouldn't do anyway).
share|improve this answer
Thanks for the clear explanation, David. I probably should have also mentioned cable length because obviously longer runs merit a heavier gauge (but only to a point). – JYelton May 5 '11 at 18:09
@JYelton The cable resistance is specified in Ohms Per Foot. So the length is factored in there when you calculate the total resistance of the cable. Be sure to use the total resistance of both legs of the cable. – user3624 May 5 '11 at 18:14
Damping factor is the ratio of the impedance of the speakers over the output impedance of your amplifier, including cabling. For instance, for 8 Ohm speakers and an impedance of 0.1 Ohm you have a damping factor of 80.
You want the damping factor as high as possible, and thus the resistance of your cable as low as possible. A bigger cable is better. It also helps to keep its length as short as possible.
For most people with lower-end audio systems, any 2-conductor 14 AWG or larger diameter wire is fine. 14 AWG, 12 AWG, 10 AWG are all fine.
Go to Home Depot / Lowes / Menards / Ace Hardware and buy cable off the reel and cut to the length that you need. For mail order, try http://www.monoprice.com
Make sure that you get stranded wire instead of one-conductor solid wire - they are more reliable.
Don't waste money on over-priced speaker cables!!!
Why wouldn't these be fine for high-end audio systems? – insta Apr 6 '12 at 16:10
discard
