Why do I get analog reading to the non connected ports, by taping the piezo in channel 1 ?
The piezo element is only connected to Channel 1 (Arduino A[0] port). The channels Ch 1 – Ch 6 are connected to female mono jacks and the ground(GND) wiring is in series from jack 1, 2 and 3 so on... till the Ch 6 end to the Arduino GND port.
The channels Ch2 – Ch6 have no piezo connected, but still connected to the arduino board. A1-A[5]
This is the serial read... first column is Ch1 … Ch 6.
Taped 3 times
787 0 0 0 0 0
191 0 0 0 0 0
19 0 0 0 0 0
937 123 63 5 0 0 < ch2, ch3 ch4 ERROR !>
86 0 0 0 0 0
13 0 0 0 0 0
507 83 126 16 8 0 < ch2, ch3, ch4 ch5 ERROR !>
21 1 1 0 0 0 < ch2, ch3 ERROR !>
0 0 18 0 0 0 < ch3 ERROR !>
This is the arduino code:
const int singnalLevel = 10;
boolean treshold = false;
int sensorReading[6];
void setup() {
Serial.begin(9600);
void loop() {
int sensorReading[6] = {0, 0, 0, 0, 0, 0};
sensorReading[0] = analogRead(A0);
sensorReading[1] = analogRead(A1);
sensorReading[2] = analogRead(A2);
sensorReading[3] = analogRead(A3);
sensorReading[4] = analogRead(A4);
sensorReading[5] = analogRead(A5);
for (int index = 0; index <= 5 ; index++) {
if(sensorReading[index] > singnalLevel){
treshold = true;
if(treshold){
Serial.print(sensorReading[index]);
Serial.print(" ");
Serial.println();
delay(1);
This is the circuit schematic.
