I'm trying to assign a 12bit parallel bus to a 12bit register. I've reduced the problem to this literal assignment but as with the previous case, only the first bit is being written to anything when I check the output. I've isolated the problem to this section, I can change the first bit data[0] but nothing else regardless of order.
Obligatory sketchy verilog:
input [11:0] ADC_bus;
always @(posedge SPIClock)
begin
count = count + 1;
if (count == 32)
begin
ADC_data[0] <= 1'b1;
ADC_data[1] <= 1'b1;
ADC_data[2] <= 1'b1;
ADC_data[3] <= 1'b1;
ADC_data[4] <= 1'b1;
ADC_data[5] <= 1'b1;
ADC_data[6] <= 1'b1;
ADC_data[7] <= 1'b1;
ADC_data[8] <= 1'b1;
ADC_data[9] <= 1'b1;
ADC_data[10] <= 1'b1;
ADC_data[11] <= 1'b1;
end
else if (count == 16)
ADCss = 1;
else if (count == 64)
begin
count = 0;
ADCss = 0;
end
end
Result: ADC_data[11:0] is always 1
