Tell me more ×
Important note: You are not helping me do my homework. This is for a competition for engineering students, that encourages you to "use your network" ;)
I've got this pattern for a frequency divider that divides the clock by 5. It's supposed to have one major problem, but I can't seem to figure out exactly what it is.
The options I have to fix this problem is:
  • X==(000|001|100), Y==(001)
  • X==(000|001|010|011), Y==(010|011)
  • X==(001|010|011), Y==(000)
  • Both a) and c) are correct!
I've taken the time to map out the signals in the original design and in option number 3, as I thought that was the answer.
http://imgur.com/dD30q
I've shifted the clock one half clock cycle, whoops. Shouldn't change anything though. The rest is done by hand.
Does anyone here have any good suggestions?
share|improve this question
up vote 4 down vote accepted
The one possible problem that jumps out at me is glitch prevention. Your output is a clock signal, so it would be very sensitive to extra edges. But it is a combinational output, so it can be prone to glitches.
Just as an example, let's say you had this naive implementation of a full carry generator (at least 2 inputs of 3 are true), namely
Y = ABC + AB(!C) + A(!B)C + (!A)BC
If your ABC signals switch from 111 to 011, there is a chance, depending on propagation delays, that the output Y, which should be a 1 the entire time, gives you a short glitch of 0. What's basically going on is that the output's trueness has to shift from one term to another: ABC -> (!A)BC in this case. If the (!A)BC term has a longer propagation delay than the ABC term for the 1 -> 0 transition on A, then both terms ABC and (!A)BC can be 0 for a short period of time, and you get a 0 as an output.
A proper implementation is one where a single input bit change produces no glitches in the output: the output's level is shared by two terms as it transitions. In the case of a full-carry generator, this works:
Y = AB + BC + CA
In your case, there are two possible causes of glitches.
One is that X and Z change at nearly the same time -- but in your case, according to your timing diagrams, this shouldn't happen.
The other is that the combinational logic that produces X is glitch-prone. We don't know how it's implemented, so that's hard to say.
The simplest solution in either case is to stick a flip-flop on the output, with the same clock input as your other flip-flops. Modern flip-flops have sample/hold specs such that any propagation delay >= 0 and < (clock period - setup time) will produce stable, glitch-free outputs, so unless your clock period is really fast, any glitch on the input of the flip-flop will settle out by the start of its setup time window on the next clock edge.
If you can't tolerate the delay of putting a flip-flop on the output, you need to guarantee that all combinational logic directly producing the output is glitch-free.
share|improve this answer
I had missed that it was a clock output. Glitches are almost certainly the "major issue". I was thinking that one of the answers had a more optimal logic solution (fewer gates). – W5VO May 12 '11 at 15:58
I'd suggest starting with a divide-by-five counter, one of whose bits is high for two counts and low for three. For example:
Q0 := !Q1 & !Q2;
Q1 := Q0;
Q2 := Q1;
This counter will go through the sequence: 000 001 011 110 100 (a value of 101 will reach a valid state after two clocks; 010 or 111 will reach a valid state after one clock). Any bit of it may be used as a two-hot output.
Take the output of this counter and feed it into a latch which is triggered by the opposite clock edge. The "OR" of this counter output with the first one would yield the desired waveform.
discard
