How do i go about using the joystick with an Arduino?
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
This is brilliant! a new Joystick from Sparkfun with the example code to getting it running on the Arduino |
I'm assuming you are using a non-USB joystick. See http://www.built-to-spec.com/blog/2009/09/10/using-a-pc-joystick-with-the-arduino/ |
Non-analog joysticks aren't that hard to make by yourself. There is an instructable that explains how to do this. |
If you're interested in using a Wii nunchuk as a joystick controller for your Arduino, you might want to check out these sources: http://todbot.com/blog/2008/02/18/wiichuck-wii-nunchuck-adapter-available/ and |
take a look here http://www.liquidware.com/projects/26/TouchShield+Tetris it's a project about TouchShield Tetris |
