I was just reading in Capacitors in DC Circuits that "Capacitors do not play an important role in DC circuits because it is impossible for a steady current to flow across a capacitor". I think it means that a capacitor doesn't allow current to flow when it's charged. What role does it have in circuits like motherboards, graphics cards, soundboards, etc. which works on DC current?
Capacitors in DC circuits have many roles, such as:
Decoupling capacitors are like an energy reservoir. The distance from the power supply can be rather long and when a component suddenly needs extra power the inductance of the PCB traces prevent this power to come quickly enough from the power supply. If you don't have decoupling capacitors this may cause a dip in the supply voltage. The nearby decoupling capacitor bridges this dip. |
That's a very misleading statement, so I suspect that it's context was important. It's only true for DC in the theoretical sense, when there is no change, ever to the voltage or current. All practical circuits are switched on at some point and have pulsed and transient currents. That's when the capacitor acts as local storage to supply current to the ICs quickly, before the power supply can act. |
The presupposition of your question is incorrect. Motherboards and graphics cards are about as far away from DC as you can get in home electronics (OK, your microwave oven might be a little farther, but not by much). Motherboards and graphics cards generate and use RF energy. That is 'RF' as in "Radio Frequency" AC. Yes, they are supplied by a DC source, but that is about where the DC part ends. Most of those caps are there to keep the RF noise that your MOBO or GPU generate from traveling to places it shouldn't and thereby destroying the functionality of the MOBO/GPU. |
