I have been working on a project for the past two weeks now and debugging this one issue has taken up this entire week. Wondering if anyone can help, I will try to be as explicit and clear as possible.
I am trying to implement a USB Virtual Comm Port on a MicroController based on the STM32F302K8 (Cortex M4). I have used STM32CubMX to generate the code needed to set up a USB Full Speed Device implementing a CDC class. My device shows up in both Windows (Device Manager) and Linux. I am able to implement a simple echo function based on the example code but when I now try to use the function USBD_CDC_SetTxBuffer to send data to the PC, this sets off a Hard Fault Handler. I have narrowed this down to the fact that the UsbDeviceFS.pClass (which is needed by USBD_CDC_SetTxBuffer) field is never initialized because USBD_CDC_Init() is never called in the initialization of the USB Device.
I have implemented fixes to several bugs (including changing the heap size, fixing the transmission flag in USBD_CDC_TransmitPacket, and changing the size of CDC_DATA_HS_MAX_PACKET_SIZE to 256 from 512) in the example code as documented on the ST forum but still getting the same errror.
My device setup code is
* USB Device Core handle declaration */
USBD_HandleTypeDef hUsbDeviceFS;
/* init function */
void MX_USB_DEVICE_Init(void)
/* Init Device Library,Add Supported Class and Start the library*/
USBD_Init(&hUsbDeviceFS, &FS_Desc, DEVICE_FS);
USBD_RegisterClass(&hUsbDeviceFS, &USBD_CDC);
USBD_CDC_RegisterInterface(&hUsbDeviceFS, &USBD_Interface_fops_FS);
USBD_Start(&hUsbDeviceFS);
