Just got curious about this last night when I was wiring a couple of LEDs on my brother's long board.
For a simple DC circuit (Battery, resistor, LED), how long can I stretch the wire until the power gets almost completely dissipated in the wire?
I know it depends on the battery and wire and everything so for like a 9V battery and 22awg solid wire...
I'm just looking for a way to come up with a rough estimate.
What about at a low AC frequency?
feedback
22 awg wire has a resistance of about 16.14 ohms per 1000 meters and has a max amperage of 0.92A according to this source. Lets say you have a purely resistive load and maximize your current with 0 wire length, your load would be 9V/.92A=9.7826 Ohms. Using this as a voltage divider you would have:
This are very rough numbers, but it is what I would use as an estimate. Low AC frequency usually acts a lot like DC. Please note though that you probably have a ground wire that has to go the same distance, so treat my lengths as "round trip". I don't know if my method is 100% correct, but this is what I do. | ||||
feedback
