I am building an ozone measuring device and am getting inconsistent and sometimes non-existent results from the sensor. the sensor is mounted separately on a piece of stripboard on the lid of the box along with a resistor and only 5 wire links. I was trying to work out why I was getting strange results when I noticed that an unconnected track had only about 150 - 300 kiloohms resistance to tracks up to 4 holes away. Once again, I stress that this track is unconnected, it just has a small amount of solder on it which I have quadruple checked is not bridged to anything. I have used acetone to wash away flux residue, but if anything, the resistance has gone down. Is there something wrong with my stripboard, my multimeter or me?
Stripboard is usually based on low cost phenolic resin material. This has the ability to absorb moisture, but this is not liable to be the problem. It is more likely that you have problems with surface contamination or with atmospheric moisture. Cleaning the board scrupulously and then applying a "conformal coating" may help. Conformal coatings (CCs) are materials designed to be applied as a spray or liquid, which then sets into a surface hugging layer that excludes contaminants and protects circuitry from corrosion and mechanical electrical contact. Numerous formal conformal coating materials are available but you also may be able to use low cost material available from many sources. If you are in the US local electrical resellers may sell purpose intended CCs. But commonly available clear polyurethane spray or "varnish" is effective for this purpose and available at low cost. Make sure that what is being sold is polyurethane and is pure, or if it is some other material that it is suitable for this purpose. Other plastics may well be suitable but a product may include other additives that render it conductive or otherwise inappropriate. With polyurethane, spray coat as you would any other item. As long as you have a continuous unbroken coating it should do the job. Coat both sides and ensure that there are no potential sneak paths from board edges. Before trying to use a CC I'd try to establish the cause of the problem.
Thinking about the above should allow you to produce a "plan of attack" that lets you measure the resistance between tracks at each step to see where the problem comes from. If you get as far as a complete working circuit with no low resistance problems, then spraying with conformal coating should allow this good condition to be "locked in". Report back ... Added - copied edited comment into answer as wholly relevant: Use 60:40 tin lead electrical solder with integral flux. Try to not need external flux. If you need extra flux, chances are that you have some other problem such as oxidized materials or materials that need a special solder (such as aluminum). Current European regulations plus those in some other administrations stipulate "ROHS" lead free construction and compliant solders contain no lead. These solders should be avoided for casual amateur use as they require higher temperatures, generally work less well with available materials and produce joints that are hard to assess visually. |
