I'm refurbishing an old Apple II Power Supply made by Astec. It's working now, but I damaged the connectors which connect the Live and Neutral wires to the Power Supply PCB. On the PCB are two posts, each about 1cm tall, and maybe 2mm in diameter, with a "bullet connector" like shape. The wires have what looks like simple cylinders which plug onto the PCB posts.
I can't find any reference to, or even images of such connectors using Google. Does anyone know what they are? I guess they might be proprietary to Astec, and possibly even obsolete, but before I do anything drastic, I'd like to try to replace them with the right ones.
Here you can see the connector in the foreground, beside the fuse:
