I'm looking to create several sine waves on a single circuit. All must be under 20Khz frequency and each must be unique. Mostly it will be 5-10 frequencies needed.
As I found - almost all crystal oscillator are in Mhz frequencies and only one kind is 32Khz (which is still too high).
I should be able to get this wave on the other side using FFT.
Ideas? :)
Thanks
