I'm interfacing the BT139-600 TRIAC with this MOC3051-M Opto-triac. I want to build a snubber circuit for the TRIAC as shown in the MOC3051M opto-triac's datasheet @ page 8, figure 12.
snubber circuit
The load will be a 230V AC, 4A motor. What are the recommended characteristics of the Rs, Cs and MOV in that schematic (the type of the resistor and capacitor, power specifications, voltage limits)? Would this components be a good pick for the snubber?
Cs: Ceramic Capacitor 10nF
Rs: 33 Ohm 5W wirewound resistor
MOV: JVR14N431K 275V AC MOV Varistor
Do I also need a snubber for the triac driver?
link|improve this question
Please specify load characteristics and use of circuit. Ideally a circuit diagram. The snubber's role is to dissipate transient energy which is looking for a home at switch off time. We need to know how much energy is there and how it is "stored" to know what sort of home it needs. As a guide you want an energy sink that will stop reactive voltage rising dangerously high, that will dissipate available ractive energy prior to the next switching cycle and which has minimal possible effect the rest of the time. Not magic, just compromise. – Russell McMahon Aug 3 '11 at 2:09
I've updated my question, so that it would be more clear. – m.Alin Aug 21 '11 at 12:02
feedback
1 Answer
up vote 1 down vote accepted
Please specify load characteristics and application. Very desirably provide a circuit diagram or at least a good word picture.
The snubber's role is to dissipate transient energy which is looking for a home at switch-off time. We need to know how much energy there is, and how it is "stored" to know what sort of home it needs. As a guide you want an energy sink that will stop reactive voltage rising dangerously high, that will dissipate available reactive energy prior to the next switching cycle and which has minimal possible effect the rest of the time. Not magic, just compromise.
Note that as your chosen optocoupler is "random phase switchable, you will have greater need of a snubber than if you were zero crossing switching - subject to the usual warnings re effects of inductive load currents not being zero at zero voltage.
To "start you on your way" ...
link|improve this answer
The first link, AN437, isn't valid. – m.Alin Aug 21 '11 at 12:04
@m.Alin - fixed! – stevenvh Aug 21 '11 at 12:18
"subject to the usual warnings re effects of inductive load currents not being zero at zero voltage" But the the current will be zero at turn-on and the thyristor will turn off only after the current (not voltage) drops to zero or am I missing something? – jpc Aug 22 '11 at 21:49
feedback
or
required, but never shown
