Yes, it is me again with a PCB Design. I am learning a lot thanks to you. This time, the specs are;
- 10-32 V input
- 35V 4A output
- Boost converter
- The controller IC is LM3478.
Schematic & PCB:
Q1 has a breakout board footprint. R1 and L1 are on the solder side. The ground line of 100 th under Q1's footprint is going to be covered with a lot of solder. Q1 and D1 are connected to a heat-sink. This is going to be a home-made single sided PCB.
