Tell me more ×
I have an old VAXstation that has an external SCSI Bus.
When I don't have anything attached to that, I get errors. I was thinking of adding a terminator, but those that I found online are quite expensive. So I was thinking of wiring one myself.
Does anybody happen to know how I should wire them, and what resistors I need?
share|improve this question
1 Answer
All the answers and information you need are on the Wikipedia page about Parallel SCSI
It mentions that SCSI-3 requires active termination instead of passive.
It then goes on to talk about termination:
Active termination means that there is a small voltage regulator which provides a +3.3 V supply. Each signal line is then terminated by a \$110\Omega\$ resistor to the +3.3 V supply. Active termination provides a better impedance match than passive termination because most flat ribbon cables have a characteristic impedance of approximately \$110\Omega\$.
share|improve this answer
OK, I'll look into it, once I get all my parts. – polemon Sep 22 '11 at 1:16
discard
