Tell me more ×
Can some one explain the concept of transistor terminal impedance? What is it, and why is it important?
Any links to useful notes/resources will also be greatly appreciated.
share|improve this question
1 Answer
up vote 1 down vote accepted
It's the impedance seen at each of the respective terminals.
It is important as it can be used to advantage in e.g. current amplification (base high impedance, emitter low impedance)
Or a (non ideal) current source (collector high impedance)
Voltage (and current) amplification (base high impedance, collector high impedance with resistor for current to voltage conversion or "transresistance")
The above is just my (probably not so great) attempt at a rough picture and is by no means the full story - any decent book on electronics should discuss the various uses of common emitter, common base, common collector amplifiers and their in/out impedance relationships and current/voltage gain. You can see how each makes use of the transistors characteristics if you study the associated theory.
share|improve this answer
discard
