Tell me more ×
I'm powering a project with a 2-cell 7.4V LiPo battery. What circuit do I add to make the unit stop drawing power when the voltage from the battery drops below 6.4V? The goal is to protect the LiPo battery from discharging below 3V/cell.
share|improve this question
up vote 2 down vote accepted
In all the following a TLV431 1.25V reference is specified.
This requires < 100 uA minimum regulation current compared to about 500 uA for the 2.5V TL431.
When on the TLV431 on voltage is about equal to the reference voltage - NOT 0V.
TLV431 current is a battery load even when output is off. At about 100 uA this drains about 2.5 mAh/day.
Voltage sensing divider is also a battery load. This can be small.
Hysteresis is not used in any of the following circuits - except the one copied from internet. A whiff of hysteresis could be used to stop battery on/off cycling when load is removed. Ask if unclear how to do this.
(1) Opamp based
P Channel FET high side switch.
TLV431 1.25 V reference.
R2/R3 divide Vmin to = 1.25V.
(2) N Channel FET, low side switch.
TLV431 1.25V reference.
FET Vth << Vmin
(3) P Channel FET, high side switch.
TLV431 = 1.25V reference.
FET Vth << (Vmin-1.25)V
(4) From web - similar to my N Channel low side circuit.
From This discussion page.
Here R6 adds hysteresis.
share|improve this answer
Thanks Russell! – Mark Harrison Sep 21 '11 at 3:53
You could use a reset IC like the MAX809. This will output a low level when the input voltage is below the device's threshold. If the input voltage is higher than the threshold the output follows the input.
You can use this voltage to switch an N-channel MOSFET, like the FDC653N.
You'll have to use a high resistance voltage divider for the input voltage, since the highest threshold available is 4.9V.
The MAX809 has several manufacturers. I prefer the OnSemi because of its low ground current.
I am not at all familliar with LiPo batteries.
But To detect the Voltage level going below certain limit, You can always use OP-AMPS...
I have this age old book... Hope it helps you--
Thanks Swanand. One aspect of LiPo battery cells is that if they are discharged below 3V they lose the ability to be recharged. – Mark Harrison Sep 20 '11 at 8:11
discard
