Tell me more ×
Any suggestions to open a surface mount package (TSOP, QFN etc) to expose the die?
Possibilities tried or considered:
  • Split the package using wire cutters - sometimes works and sometimes doesn't
  • Grind the top off with grinder - Some chips have no cavity between the die and the cap.
  • Soak in MEK - I heard this works but haven't tried it.
Why would I want to do this? To photograph for forensics purposes - to look for damage or to get die numbers. I don't expect the part to function afterward. Electronic forensics labs seem to be able to open chips easily but I'm not sure what tools/techniques they use.
share|improve this question
just what you need - "aqua regia" – user5969 Sep 29 '11 at 2:48
this mentions tear-down companies that open chips. – JimFred Sep 29 '11 at 3:00
Anloy Chip Extraction – JimFred Sep 29 '11 at 15:51
up vote 3 down vote accepted
Travis Goodspeed has the tutorial: http://travisgoodspeed.blogspot.com/2009/06/cold-labless-hno3-decapping-procedure.html Basically you put the part in a test tube with NO3 and swirl it around and leave it overnight until the encapsulation is dissolved.
Only slightly related, but look through Travis's Flickr stream for a lot of interesting dieshots.
share|improve this answer
NO3 is nitrate, not nitric acid. Do you mean HNO3? – Connor Wolf Feb 4 at 10:35
Hot red fuming nitric acid is the stuff to use, it dissolves the plastic. It's rather nasty, several kids in my class at school got acid burns when an experiment performed by our chemistry teacher went wrong and there was an explosion.
I suppose I could use a Styrofoam cup on my lap with my best trousers on. – JimFred Sep 29 '11 at 2:49
I've got to put on new trousers just thinking about it. – kenny Sep 29 '11 at 2:55
Lol gotta love HS. – Kyle Sep 29 '11 at 3:02
Sulphuric Nitric mix. Boil. Fume extract. DO NOT add organics !!!!!!!!!!!!!!!!!!!!! Acid splashes (small) on clothes leave holes with brown oxidised edges. – Russell McMahon Sep 29 '11 at 6:33
@kenny - perhaps you've heard Ira Remsen's cautionary tale regarding nitric acid? chem.ucla.edu/harding/Rensenquote.html – JustJeff Sep 29 '11 at 12:24
discard
