How can I write the bootloader and sketch code to an Arduino through the ISP and then write the sketch code again using the Arduino IDE later?
Currently, I can write the bootloader through the ISP and then write the sketch through the Arduino IDE. This works just like normal.
I can also write the bootloader and sketch through the ISP. The code runs like normal, but I can't load a new version of the sketch through the Arduino IDE. It just timesout.
Here's what the IDE says when it attempts to upload the program:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
The Arduino IDE creates two hex files after compiling the sketch: one is just the compiled sketch (Sketch.ino.hex) and the other is the compiled sketch with the bootloader code appended to the end (Sketch.ino.with_bootloader.hex). So, I feel like this should be possible because Arduino produces the file for me.
