Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am working on a lab for school and did forgot to measure min and max of waveform to obtain the offset, but I do have the RMS and peak to peak values.
I tried using the following to calculate DC offset, but this does not agree at all with simulated results or waveform displayed in the screenshot using the divisions.
DC offset=Vpp/(2*sqrt(2))-Vrms
Is my logic off? Can this not be computed properly from a scope measured Vrms value?
Props to anyone that can deduce the circuit haha!
share|improve this question
Are you sure that the scope didn't actually filter the DC offset? Can you post a screenshot of the waveform? – AndrejaKo Oct 7 '11 at 8:07
Gnd should be lined up on the y axis...RMS of ch2 should be same as is the ch1 rms if DC offset was filtered? – user623879 Oct 7 '11 at 8:15
up vote 5 down vote accepted
Summary:
  • RMS powers can be added.
    So - RMS Volts^2 can be added.
  • Offset = Vdc = sqrt( Vrms_total_signal^2 - Vrms_ac_only^2)
    = sqrt (5.452^2 - 5.175^2) = 1.716 volt
(Voltages above are mean RMS voltages from supplied table. )
Calculating AC only RMS from Vpk-pk would give
  • Vrms_AC = (Vpk-pk)/2 x 1/sqrt(2) = Vpk-pk/2.sqrt(2)
    = 14.68/2/1.4142 = 5.190 V RMS.
The RMS voltage displayed is 5.175V mean suggesting that
the signal is not quite a pure sinewave
and/or that the measurement system is not 100.000% accurate (of course).
5.19 / 5.175 = 1.0029 or about 0.3% higher.
"RMS powers" add directly.
ie Power total = Power_ACV + Power_DC
Power is proportional to V^2 so
(Vrms_AC+DC)^2 = (Vrms_AC)^2 + (Vrms_DC)^2
as Vrms_DC = Vdc
Vrms_combined^2 = Vrms_AC^2 + Vdc^2
or Vdc^2 = Vrms_combined^2 - Vrnms_ac^2
So Voffset = Vdc = (Vrms_combined^2 - Vrma_ac^2)^ 0.5
Here
Vrms_ac = 5.175V average (from table)
Vrms_combined = 5.452 mean
So
Voffset = sqrt( 5.453^2 - 5.175^2) = 1.716 Volt.
share|improve this answer
awesome, thx... – user623879 Oct 7 '11 at 16:48
discard
