Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
When combining battery cells in series, the voltages of the cells are added to get the voltage of the final circuit.
Do the mAh add up, or stay the same?
For example, suppose you have two 3.7V cells, each with 200 mAh capacity. When connected in series, will the resulting battery will be a 7.4V, 200mAh battery?
share|improve this question
CONSIDER ALSO THE INTERNAL RESISTANCE OF THE BATTERY, IF YOU CONNECT THEM IN PARALLEL, RESISTANCE DECREASED AND CURRENT INCREASE. – user54343 Oct 1 '14 at 4:27
Well, do the mA (i.e. current) add up, or stay the same? If the cells are in series, the current through each cell is the same. Since the time (hours) would also be the same, you answer is clear. – DaveBoltman May 13 '15 at 5:54
up vote 20 down vote accepted
Summary
  • mAh stay the same when you connect cells in series - provided that cells are all of the same mAh capacity.
  • Special and unusual case If two cells are connected in series and they have differing mAh capacities the effective capacity is that of the lower mAh capacity cells. This is not normally done, but it can sometimes make sense to do so.
  • mAh add when you connect cells in parallel (but there are technical issues which mean that doing this may not be straightforward.)
The answer can be deduced by considering what mAh capacity means:
mAh = Product of ma × hours that a battery will provide.
While there are (as ever) complications, this means that eg, a 1500 mAh cell will provide 1500 mA for one hour or 500 mA for 3 hours or 850 mA for 2 hours or even 193.9 uA for one year ( 193.9 uA x 8765 hours = 1500 mA.hours).
In practice the capacity of a cell varies with loading. A cell will generally produce its rated capacity if loaded at its C1 = 1 hour rate. eg 1500 mAh = 1500 mA for one hour. BUT a 1500 mAh cell loaded at say 5V (5 x 1500 = 7500 mA = 7.5A) will NOT do this for 1/5 hour = 12 minutes - and may not produce 7.5A at all even on short circuit. A load of say C/10 = 150 mA or C/100 = 15 mA may produce more than 1500 mAh overall BUT a load of say 150 uA = 10,000 x as long = 10,000 hours = about 14 months may produce less than 1500 mAh if the battery self discharges rapidly with time.
BUT
If a cell will produce say 2000 mA for 1 hour at 3.7V (a typical rating for liIon 18650 cells) then two identical cells will do the same thing if tested independently. If instead of using 2 loads you connect the cells in series and draw the same current as before the identical current flows through both cells. You can still here only draw 2000 mA for one hour BUT the available voltage has doubled.
If you use 2 x 3.7V, 2000 mAh cells in parallel to drive a 3.7V nominal load, one cell can provide 2000 mA for one hour or 200 mA for 10 hours etc AND the other cell can do the same. So the mAh ratings add.
If one cell has more mAh than the other, the mAh TEND to add when connected in parallel. Say you have 1000 mAh and 2000 mAh cells in parallel, each rated at 3.7V nominal, as the smaller battery loses capacity it will tend to reduce in voltage faster so the larger battery will provide more current so they will TEND to balance. YMMV and this is usually not good practice without specific design of what happens.
In the special case I mentioned above, you may have a 12V 7AH sealed lead acid "brick" battery beloved of the alarm industry. You may want to use an N Channel high side switch which needs a gate voltage of say 4V above the +12 rail. If you use a 9 Volt PP3 "transistor radio battery" and connect its negative terminal to +12 V then the PP3 positive terminal will be at 12+9 = 21 V initially. The N Channel MOSFET needs 12+4 = 16V so the PP3 + SLA combined followed by a regulator will operate it until the combined voltage falls to under 16V. This should be never happen, as the PP3 "dead voltage " = 6V and the Sla should not be under say 11V so minimum Voltage available = 11+6 = 17 V.
If you use this occasionally, and disconnect battery when not in use, the PP3 will last a long time. If the PP3 is rated at say 150 mAh, and if the FET high side cct takes a steady 10 mA when oj then the PP3 will last for ~~= 150/10 = 15 hours. This may be acceptable or not depending on the application.
BUT the SLA has a 7Ah = 7000 mAh capacity BUT the combination can only provide 150 mAh at >= 17 Volts. So the mAh effectively is that of the much smaller PP3. This is for the task which needs the combined voltage - the 12V output still has the full 7Ah capacity.
share|improve this answer
@MarkHarrison - thanks - yes - 43 hours was a bit long. I just changes Sla to SLA but I'm sure there will be more. Brain and fingers are only moderately well connected. They taught the boys metal work and the girls typing when I was at school. We wuz robbed :-). – Russell McMahon Oct 10 '11 at 9:01
It is worth making it clear that although you don't increase the mAh, the mA's required to power your device may decrease when you double the voltage, thus increasing your run time, but then again, it might not if you are using an inefficient means of voltage regulation. – Kellenjb Oct 10 '11 at 16:05
@Kellenjb - You are correct (of course) that the energy of the battery increases and that a switching power supply is liable to make good use of this. That was NOT of course what the question was about BUT it wouldn't hurt to add it. The question related to effect on battery mAh which is energy content independent (but a close cousin). But, I know you know that :-). – Russell McMahon Oct 10 '11 at 16:13
I realized that wasn't the specific question, but I know that can be a point of confusion for some people, and would be very relevant if this question was being asked by someone trying to decide if they wanted to design with 2 batteries in parallel or series. – Kellenjb Oct 10 '11 at 16:39
When you add the cells in series only the voltage is added. The current capacity (mAh) remains the same.
When you connect them in parallel only the capacity increases while the voltage remains constant.
If you need both the voltage and current to be increased try a serial parallel combination
In your example the result will be a 7.4V 200 mAh Battery.
protected by Dave Tweed Dec 14 '14 at 13:28
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
