Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
This is probably a very basic question but I have the following circuit, I am not sure what is in series and what is in parallel or if they are all in parallel, initially I thought R2 and R3 were in series and then used the sum of their resistances with R1 to calculate the equivalent resistance, that seems to be off based on some circuit simulation software I am using so I would appreciate if somebody could explain how to calculate the Rt and the logic behind it.
Thanks.
share|improve this question
Come on, just redraw the circuit with R2, R3 vertical... – Eugene Sh. Jan 6 at 16:05
@EugeneSh., I have done very little with circuits, if it were obvious for me I would not be asking question. – Padraic Cunningham Jan 6 at 16:10
up vote 16 down vote accepted
An easy thing for the beginner to do, is color the nodes.
Circuit with colored nodes
Now, any components that have the same color (node) on each end are in parallel. So, R2 and R3 have green and purple on each end (respectively) so they are in parallel.
share|improve this answer
Thanks, Tyler, that makes it a lot easier. – Padraic Cunningham Jan 6 at 16:29
I highly recommend to re-draw the circuit. Take a pencil, paper and re-draw the circuit. Trust me it will help.
Pro tip: next time use the built in schematic editor: CTRL+M – d3l Jan 6 at 18:09
@Julio, its only easy to redraw it when its already obvious whether each part is in series or parallel. – Octopus Jan 6 at 23:12
discard
