Tell me more ×
As I understand it, the life of an EEPROMs is usually rated at a certain number (e.g. 100k) of writes. Is this "per byte" or writes to the EEPROM system as a whole?
E.g. If the EEPROM has 4k bytes, could I conceivably make 400 million writes if they were evenly distributed?
Specifically, I'm talking about the EEPROM in the Arduino Mega 1280/2560.
Debrief: Thank you stevenvh and Majenko for your helpful explanations. I asked because I wanted to know whether I needed to bother updating only dirty variables when saving a lot of data (a large configuration). From a wear perspective, the answer seems to be 'no': wear happens at the "bit level" and is only caused by setting bits to zero. From a speed perspective, perhaps it would make sense to minimise the size of writes, but if this is not a consideration for your application, then you needn't stress out about it.
share|improve this question
up vote 8 down vote accepted
It's not just write cycles that's specified, but erase/write cycles. On the AVR EEPROM can be erased by byte. Erasing sets all bits to 1, writing selectively clears bits. You can't program a 1, just 0s. If you want to set at least one bit to 1 you have to erase that byte.
Erasing removes the charges from the FET's floating gate, but on each erase cycle some of the charge remains on the floating gate, which won't be removed through the quantum tunneling. This charges accumulates and after a number of cycles there's so much charge left on the floating gate that the bit still will read 0 after erasure. That's what determines EEPROM life, it's erasure rather than writing. So you can safely write additional 0s, as long as you don't erase.
As a result, if the datasheet specifies 100k erase/write cycles you can have maximum 800k write cycles, one bit at a time, for 100k erasures.
If you're using only part of the EEPROM memory space you can extend its life by distributing the data, like Matt says this is called wear leveling.
The simplest method of wear leveling when writing blocks of data is to include a counter with the data. Suppose you need to keep 14 bytes of data. Add a 17-bit counter as two bytes, you probably have a bit to spare for the 17th bit. Increment the counter before writing the block of 16 bytes. If the counter has reached 100 000 you know this block is becoming unreliable, so you move to the next 16 bytes. Use this until it is worn as well. And so on. A 4k memory consists of 256 sixteen byte blocks, so you can extend the original 100k cycles to 25 million.
It should be obvious that your gain is greater with smaller blocks of data.
further reading
data retention on a microcontroller
share|improve this answer
Wow. Thanks so much for your comprehensive answer. – aaaidan Oct 23 '11 at 23:34
It is per bit - or more specifically - per gate.
What you propose is known as "wear levelling" and is commonly used to extend the life of flash memory - especially SSD drives.
Can most EEPROMs erase a single bit? I thought the smallest write they could perform was a byte. – Connor Wolf Oct 23 '11 at 9:42
When you erase an eeprom you set it to all 1's. When you write to an eeprom you change the 1's to 0's - so writing 0b11111110 will infact only be changing one bit. Yes, you are 'writing' a byte, but only a single bit is being changed - thus only that bit is being worn out. – Majenko Oct 23 '11 at 9:53
Thanks for that explanation: super helpful. – aaaidan Oct 23 '11 at 23:35
There are some variations in flash and EEPROM technology, but at least with some flash technologies, hitting a bit with just enough "oomph" to write a zero and then later hitting it with just enough "oomph" to write a "1" would typically not cause a whole lot of wear. On the other hand, hitting a bit with an excessive amount of energy to erase it can cause considerable wear. Unfortunately, it's not practical to regulate the precise amount of energy used to write and erase individual bits. Instead, one must hit an entire block with an "erase" pulse at once, and even if every bit were identically programmed, some bits will erase faster than others. If one weren't interested in erase speed and one had the ability to read bits as being 1/2-charged, 1/4 charged, 1/8 charged, or less, it might be possible to improve endurance by hitting the entire array with a short erase pulse and then, if every bit was more than 1/4 charged, hitting all the bits that were at less than 1/8 charged with a pulse that would charge them by about 1/8 (so that they would end up between 1/8 and 1/4 charged), then hitting the entire array with another erase pulse, etc. until no bit was more than 1/4 charged. Such an approach would avoid over-erasure, which is one of the major wear factors on flash memory. Unfortunately, such an approach not only add complexity--it would probably at least double erasure times, and probably increase them more than that.
discard
