Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have an old mp3 player which originally ran from a 3.7V LiPo battery. It could be charged from USB using a mini-usb connector. The device goes into charging mode when power is present at the usb charging port, but will not operate in playback mode without voltage at the battery terminals. The battery is long dead and I removed it and soldered a connector to the battery input of the circuit. Using an adjustable regulated supply I can run the device by supplying 4.25V at where the battery used to be (the battery indicator shows "full" at 4.2V and "low" at 3.6V) or from 3 AA batteries, however I would need a smaller wall-plugged power source for practical (stationary) use. I tested the device using a smartphone charger and ran it briefly (2 minutes) with no apparent problems. The measuered voltage was 4.85V. I would need some advice on the following:
  • What (if any) problems could arise from running this device at 4.8-5V? The device expects around 4.2-4.3V (voltage of a fully charged LiPo), so this would be 0.6-0.8V higher. Short test operation (about 2 min) went fine, could there be problems if playing back music for hours?
  • Is there any way to diagnose such problems? Perhaps by measuring temperature on the surface of the IC?
  • What are the possible consequences? Besides device failure, could this also cause a fire hazard?
Here is an image of the player's internals:
mp3 player circuit
The square IC is marked M7103A-A1, however I could not find a datasheet for it. The rectangular IC's markings are unreadable. The cable in the lower right corner is where the battery used to be. The charging port is on the lower left.
share|improve this question
A small, lazy and cheap solution is to get a step down converter and maybe a micro usb breakout from ebay (or somewhere else). Shipping might take some time. – someonr Jan 22 at 18:25
The main risks in this include, but are not limited to:
  1. Excess power consumption and conversion into warmth. The prior may not be too important, the latter might, but can be managed with proper additional heat-sinking. If you will, you could put the entire PCB inside dense bubble-free epoxy and cool that with some metal fins externally, or in specialty thermally conductive putty or silicone resin. Or, poor-man's tool: 2 component glue for tries.
  2. Over-biasing internal circuitry on power-supply. Though unlikely, it is possible some analogue part starts to get close to over-biased at 5V. Most cheap MP3 players directly power everything with the 5V input, only switching operation mode based on its presence, so the chances are slim of this happening.
  3. Over-biasing internal circuitry on signal-levels. This is somewhat more likely, but still not hugely so. Some devices of cheaper chip design may have simple resistive dividers for set-points and biassing internal audio paths, coming directly from V+. This would mean, however that your player would always have been dependent on charge state for its audio crisp-ness. Over biasing and wrong set-points can cause: Clipping, distortion and unintended higher output power, leading back to part 1.
  4. Power spikes from the adapter causing irregular voltage wobble in places it's not expected, since single cell LiPo batteries hardly ever make a 7V blip.
What can you do? Simple!:
That schematic is very complex for the purpose, but I thought I'd add in a few inductors and capacitors by way of "proper design" to take out some possible noise sources, since one reason they may have decide to not be able to play music when charging is that cheap adapters cause a lot of icky noise that may influence your playback, even only intermittently.
These solutions aren't a be-all and end-all for noise problems, but they will definitely help and should be doable with relatively cheap components.
But, if you don't care about noise, you can probably do with just this:
The diode is a "lossy" component and an old-fashion silicon PN type like the 1N4001 (which is also dirt cheap due to massive production numbers) will take up about 0.6 to 0.8V in the forward direction when some current goed through.
To make sure always a little current flows, the resistor is there and the capacitor is just there to smooth out any small disturbances in the... voltage. Ahw. Only just not put in the quote. Couldn't do it guys, sorry.
Edit: Inclusion of the answer to the question "Why the resistor?" in comments:
Asked in the comments: "Why that resistor 'to always drain a little current'?"
The Answer I gave:
Because you do not know how the device works and at times of inactivity a battery powered device may very well drop to several uA or less of current usage, in which case the diode will no longer be strongly forward biased and the dropped voltage will not be fully reliable anymore. The resistor can probably be increased to 2k or even 5k to equal the static (quiscent) waste in an affordable linear regulator.
Secondly with no resistor a turn on/turn off spike of the adapter with the chip only using 1uA can charge up the capacitor to 10V or more for extended time with cheap adapters. Some 'more affordable' adapters can as a death throw when the mains voltage runs out, or even when it is first plugged in, create a small, low-energy pulse that goes outside their normal regulated voltage. If a device is draining a few mA or more, those spikes usually cannot manage to cause more than a volt above regulation for a short bit of time. But when the device drains nearly no current, that energy may go into over-charging your filter cap beyond a mere volt.
share|improve this answer
Thanks. I'm not exactly sure though about R1's function. You say "to make sure always a little current flows" - would this also apply when the device is powered off but connected to the adapter? Why is this necessary? – alchemist_anonymous Jan 22 at 14:36
@alchemist_anonymous because you do not know how the device works and at times of inactivity a battery powered device may very well drop to several uA or less of current usage, in which case the diode will no longer be strongly forward biased and the dropped voltage will not be fully reliable anymore. It can probably be increased to 2k to equal the static (quiscent) waste in an affordable linear regulator. Also with no resistor a turn on/turn off spike of the adapter with the chip only using 1uA can charge up the capacitor to 10V or more for extended time with cheap adapters. – Asmyldof Jan 22 at 14:55
Your question is impossible to answer without detailed knowledge of the design. Heat is not the only thing that can kill devices in this situation. Voltage can too. Fire hazard is very unlikely here, though. If you care about your mp3 player, find an adapter that outputs in the battery voltage range that you have identified, or put a V regulator in series with the supply, to give you the ~ 4V you need. If you don't care too much, try it and see what happens. It may work fine.
I wouldn't try to replace the LiPo, as they can explode or catch on fire if mistreated, and the involved circuitry may have already been damaged by your tests. – Peter Frey Jan 22 at 14:09
I made an LM317 regulator circuit to provide 4.2 V, however 1. it is a waste of energy 2. it needs a heatsink and can be quite bulky 3. I started to wonder - if the device turns on fine using the 5V provided on the charging port, and it is actually specified to 4.2V, then it might be able to run from 5V as well. Another thought I had was to simply drop 0.5-0.7V from the 5V power by a series diode and save the hassle with the external regulator. I did not try to replace the LiPo for the reason you cited. Actually I was shocked to find out I was carrying a LiPo in my pocket for a few years. – alchemist_anonymous Jan 22 at 14:16
@alchemist. I would contend that your LM317 solution is better that the diode circuit above. It will dissipate only the power it needs to to regulate the voltage. And it will regulate better, eliminating the possible issues with voltage spikes that were previously mentioned. All the power dissipated in R1 above is wasted, and heat that you then have to deal with. It's also fewer parts... – Peter Frey Jan 22 at 20:10
You may want to post your LM317 circuit so we can review it. – Peter Frey Jan 22 at 20:12
A LM317 won't work very well since it requires about 2V to regulate properly. Using a LDO for the task would fix that issue. But converting a 5V signal to 4.2V is not that bad with a linear regulator - nominally 84% efficient. I'm skeptical that a battery powered device would heat a linear regulator to the point of needing a heatsink – W5VO Jan 22 at 20:16
discard
