Tell me more ×
I have the circuit of the amplifier below. I want make the DC analysis and find the gain the amplifier produces and the cutoff freq(high-low).
My problem is that it's been 15 years since I was student and I remember nothing. I will appreciate any help provided.
share|improve this question
That's a SPICE schematic. Download a suitable SPICE simulator, such as LT SPICE, enter the schematic and do the analysis. – Leon Heller Oct 30 '11 at 9:00
Thanks. I didn't know about LTspice. – dempras Oct 30 '11 at 9:14
Here is my simulation. – dempras Oct 30 '11 at 9:39
This doesn't answer your question, but you may be interested in this presentation (starting at about the 25:20 mark): infoq.com/presentations/We-Really-Dont-Know-How-To-Compute – markrages Oct 31 '11 at 10:25
up vote 4 down vote accepted
I did the DC analysis by hand:
Summary:
Theoretical:
Ib = 5.963uA
Ic = 895uA
Ie = 900uA
Vce = 7.362V
Spice:
          --- Operating Point ---
V(n002):     6.71675     voltage
V(n005):     0.895875    voltage
V(n006):     0.248847    voltage
V(n001):     12  voltage
V(n004):     0   voltage
V(n003):     1.47768e-014    voltage
Ic(Q1):  0.0011241   device_current
Ib(Q1):  7.02464e-006    device_current
Ie(Q1):  -0.00113112     device_current
I(C2):   6.71675e-019    device_current
I(C1):   -8.95875e-020   device_current
I(R5):   -6.71675e-019   device_current
I(R4):   0.000497708     device_current
I(R3):   0.000504733     device_current
I(R2):   0.00113112  device_current
I(R1):   0.0011241   device_current
I(V2):   -0.00162883     device_current
I(V1):   8.95875e-020    device_current
Then the AC analysis:
Gain: enter image description here
Summary:
Theoretical:
Voltage Gain: -17.6
Spice: enter image description here
This gives you the -3db points:
f-low: ~= 500Hz
f-high: ~= 24MHz
Comments:
As you can see the theoretical and Spice DC analyses match closely. Spice differs since it takes many more factors into consideration.
share|improve this answer
Thank you very much. I 've expected something like this in order to understand. – dempras Oct 31 '11 at 6:30
Impressive. Can you suggest any textbooks on this matter? – artistoex Nov 21 '11 at 11:18
@artistoex "Neamen: Microelectronics Circuit Analysis and Design (McGraw-Hill)" I think it is this book on Google books: books.google.co.za/… – Konsalik Nov 22 '11 at 19:48
He's also written about semiconductor physics. Seems to be a very productive author. Thank you very much! – artistoex Nov 23 '11 at 13:51
I made the library purchase the book. Unfortunately, in the preface it says DC analysis would be a prerequisite. – artistoex Jan 25 '12 at 16:23
Simplistic but possibly useful starter:
1. Gain
The load current flows in both the 4k7 and the 220r resistors.
So relative voltage ratio between THE two resistors is proportional to their resistances
as V=IR and I is common to them both.
Vin aPpears Cvross the 22r and Vout across the 4k7 so
gain is ~~~= 4k7/220r ~= 21.4 or
Gain ~~~= 20.
2. Maximum possible single stage gain
Many people deny this formula is 'real'.
It is.
NB the following is a magic formula which you can either remember and use or you can choose understand it. This is true only for silicon bipolar transistors.
  • Max gain (magic formula) = 38.4 X available voltage
    = here = 38.4 x 12V.
    = 38.4 x 12 =~ 460
So Maximum possible gain is ~ 450
NB emitter reisistor must be bypassed (See below) with a suitably large cap when relying on Re alone for gain.
Available voltage swing is ~ 0 at this gain as all of Vcc needs to be dropped across Rl to maximize current to make dynamic Re small to make gain large.
Arcane mumblings re above:
  • The above occurs when the 220 R is bypassed with a large enough cap so that it is ~~ 0 ohms to ground at signal frequency.
    The gain then becomes 4k7/Te where Re is the emitter internal resistance.
    It happens as a caracteristic of silicon thet the internal Re - 26/mA. ie Re is 26 ohms at 1 mA, 13 ohms at 2 mA, 0.26 ohms at 10 mA etc.
    mAx gain occurs when Re = minimum = when current = maximum. This occurs when all voltage is across load )almost) so i= 4k7/12 ~+ 2.55 mA.
    From above Re = 26/2.55
    So max gain = 4k7/(26/2.55) = 460.
  • Rearranging the above shows that Max Gain = Vsupply x Rload
discard
