Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
What is the best way to implement an output but with also a led, so I can use the output for other purpose (for example a GPIO for a PIC, or a lot of logic gates) but with a led indicador that the output is in high? I want to preserve the enough current for the led, and have a nice HIGH (5V, 3.3V..) value I did 2 circuits, is there a better way?
share|improve this question
up vote 4 down vote accepted
If driving reasonable inputs, move the output BEFORE (to the left of) the resistor in your Circuit 2 and it should work fine. If driving unreasonable inputs, you'll need a buffer.
Use a resistor as large as you can get away with (experiment) and still see the LED light up to minimize load on the output from the LED. Many modern LEDs are quite visible with a milliamp or two, rather than needing near full rated current to be visible like the ones of days gone by.
share|improve this answer
Regarding "reasonable inputs" they should look at the high-level input current of the device they're driving, add the current through the LED branch, and make sure the GPIO can supply that much. Good datasheet exercise. – Jay Keegan Feb 6 at 2:50
I fix the 2nd circuit :) – Pulse9 Feb 6 at 3:03
In parallel to the led + resistor. Optional Resistor to keep the GPIO within it's recommended current limit. Adjust values as needed.
Logic level, high-impedence inputs could be connected directly without a resistor.
discard
