Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
How often should I tin my soldering iron? It doesn't seem to pick up the solder quickly any more; I have to hold it there for 10 seconds before it melts.
share|improve this question
That sound like your iron isn't heating properly, not that you have a dirty tip. – Connor Wolf Jul 17 '10 at 10:20
Actually, oxide buildup (especially with the higher temperature lead free solders) can behave a lot like insufficient heating, in that it impedes heat flow from the iron to the work. – Chris Stratton Nov 30 '15 at 2:34
12 Answers 12
A much cheaper option than the metal shavings coated in flux, is to put a pan scourer like this one:
Pan scourer
in a small container, and use that to clean the excess solder off of the tip, it seems to do a reasonable job and doesn't cool the tip excessively. Although you don't get the benefit of the flux which coats the shavings either.
(A tip: make sure that the scourer isn't plastic!) ;-P
share|improve this answer
9
Make sure you don't use a steel wool based scouring pad, or you'll damage the tip of your soldering iron, and get rapid oxidization as well. Must be brass! See this one: elexp.com/sdr_3460.htm, which comes in a weighted metal container with a rubber bottom for $5.75, replacement cleaners for $2.95. – Kevin Vermeer Jul 15 '10 at 17:48
Copper works fine too. I wonder about aluminum, maybe that would not be a good idea as aluminum oxide is quite hard. – jms Feb 2 at 19:46
Here's a really good video and comprehensive FAQ that explains all about soldering (and when and how to tin your iron).
[EDIT]
As suggested by @anddam, you may wish to view the YouTube video directly instead of the using the embedded flash video in the article.
While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. Link-only answers can become invalid if the linked page changes. - From Review – Brian Carlton Nov 30 '15 at 2:50
@anddam, you should have added your own answer, instead of editing mine, but I'll let it stand. – Craig Trader Feb 2 at 17:04
Well, I didn't know about that page in first place and it occurred to me that the whole point of the site is build better answers, not more of them. Thanks for the explicit mention. – anddam Feb 2 at 22:33
You should tin the soldering iron whenever any part of the tip does not have a shiny appearance.
Flux is a good tinner, so if you don't have soldering iron tinner then just keep melting solder with flux onto the tip wherever it's not shiny and let the bubbling flux do its job.
I use a brass pad type tip cleaner rather than a sponge - water will corrode the tip quickly, so I've completely moved away from damp sponges.
I also add a little solder to the tip every time I place it in the stand (and wipe the excess off when I pull it out) this puts a layer of solder coating the tip so it doesn't oxidize in the air while it's sitting there waiting for me to pick it up again. When I turn it off, the solder blob stays on the tip and protects it long term when not in use.
Since starting this technique I haven't had to fully re-tin my tip in years, and my tips do not develop the pitting and corrosion I used to experience.
Keep in mind that to solder some things it'll heat up a little faster if you keep a bit of solder on the tip, and touch that to the part and PCB pad - the solder blob will transfer heat more effectively than the bare metal will. If the tip won't hold solder, it won't heat the joint effectively.
This is going to sound kind of basic, but it took me a while to figure out that I had to occasionally pull the tip out of the iron, and clean out the socket and the back of the tip. Get enough rust or other junk in there and you'll never get good heat transfer from the iron's heater to the tip itself.
I used to wipe my tip on a wet sponge after every couple of solder joints. You definitely don't want it to look dirty. This retinner can be used if things get really bad (it seemed like that happened every couple of hundred joints). If you don't want to buy that, then just melting a bit of resin core solder onto the tip works almost as well (but adds its own dirt...).
More recently, I've been using a brass sponge on a temperature controlled soldering iron. I haven't needed to retin at all. I don't know if it's the better iron or the brass sponge. In other news, I'm completely in love with that soldering iron. It heats up very quickly and then stops without getting too hot. The tip doesn't show any wear, despite quite a bit of use. One of the best purchases I've made in this hobby.
Metcal recommends de-ionised water on the sponge, but I don't bother. Most of my cartridges have lasted for a couple of years, which is a good thing as they are rather expensive.
They supply a brass cleaner with their new MX-5000 system, so that is probably the thing to use with other systems.
If you're holding the solder to the tip and it's not melting it's because 1) the tip's not hot or 2) it's really dirty. Both are things worth checking.
Other answers talk about the range of options to clean the tip, all good, all dependent on your particular tip. The point of all of them though is that you don't want to score the tip, you want it clean and intact, without pitting or scrapes, so be gentle. In nearly all cases, the tip will be hot when you're cleaning it.
A trick I learned from an aerospace tech is to use a lot of solder when I clean the tip, using the excess solder to almost 'flush' off the tip. Flux or Rosin is your friend to help distribute heat, but don't leave it on, as it will corrode. Alcohol cleans rosin up nicely.
Just as a note too, you'll buy "flux", but make sure it's a "rosin" flux. There are many kinds of flux, and the rest are unsuitable for soldering irons and pcbs. They might work in the short term, but cause endless headaches in the long run with corroded parts.
In order to prolong your soldering tip life, you should tin you soldering iron every time after you finish soldering. Here's an easy method:
  1. Wipe the flux with solder sponge or soldering tip cleaner
  2. Tin the tip with fresh solder.
  3. Put the iron back to the holder.
Doing this can protect your tip from being oxidized.
I use Multicore Tip Cleaner. It's solder powder mixed with an aggressive flux and does a very good job with my Metcal cartridges when they need tinning. I just poke the tip in the cleaner and wipe it on the sponge. My cat seems to like the taste of the stuff so I have to keep it covered when I'm not using it, otherwise he licks it, which isn't very good for him.
I think it can depend on what type of iron/tip you have. I've got a ceramic tip and the manufacturers instructions say not to use an abrasive to clean it. I use a wet natural sponge to clean off dirt whilst soldering, and I tin the tip with pre fluxed solder after every use, when it gets dirty I clean it off with the natural sponge, then leave it to cool down. Once cooled I use isopropyl alcohol and a cloth to polish the tip. Normally I'd clean it in this way once a week, and I use my iron daily. Over all this method seems to preserve the tip for longer I've been using the same one for nearly three months now and it shows no signs of letting up.
So I'd say the first port of call for finding out how to look after your tip, is to contact the manufacturer and see what they recommend.
By the way, don't use a synthetic sponge, they melt! – Jim Jan 9 '10 at 15:07
Sometimes when it takes an iron a long time to melt solder, the problem is that oxides have built up in the thermal joint between the heating element and the tip, reducing the ability of the element to keep the tip hot. This is easily remedied by simply loosening and re-tightening the screw or collar the holds the tip in contact with the heating element.
With gun type irons, there are usually two set screws, one for each leg of the tip. In this case, the tip is the element, so the oxides present electrical resistance, but this accomplishes pretty much the same lack of heating. Just backing the set screws off half a turn and re-tightening is usually enough to restore the heat to this type of iron.
Of course, it doesn't hurt to periodically take these things apart, and clean them up with a small wire brush, either. I use the same brush for this that I use to shine up component leads and surfaces before soldering them.
In most case like this I’m used to get the soldering iron needle out, attach it to an electric drill and get it sharpen with a smooth sand paper while the needle is rotating.
  • It will gives you a symmetric, very clean needle point.
No. Modern soldering iron tips depend on plating - if you remove non-trivial amounts of material from this, you have only the core metal left which will oxidize very quickly, meaning you will have to do this for every use. – Chris Stratton Nov 30 '15 at 2:33
Yes, I agree. But it seems that the plate is already damaged. If the palate is already damaged giving a fresh solder bath after cleaning solves my problem. – binu Nov 30 '15 at 7:44
protected by Olin Lathrop Jan 23 '13 at 19:44
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
