Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am interested in making my own cheap (somewhat disposable, or permanently attached to prototypes) probes for my oscilloscopes.
In complex circuits, and dense PCBs sometimes it may be difficult to attach all these (standard)probes, test points may not be available, the connections may induce great ground impedance distorting the signals, etc...
The solution I came up with it to solder some coaxial cable to a BNC connector, and solder the cable directly to the "interesting" trace on the PCB, making a more robust connection (no hooks to detach, very annoying), greatly smaller grounding leads. Permanently attaching the probe will result in a perfect prototyping/developing board, always providing all the signals, ready to be connected to the scope.
How may I accomplish this? The signals may be in the MHz range (10-30MHz for example).
I was thinking of standard 50-ohm coaxial cable, is there anything better? Should I terminate it?
For 1:10 probing I thing a simple voltage divider is enough. Is that true?
How about capacitance compensation? How to generally reduce the capacitance of the probe?
Anything else to keep in mind, about the probes? Or any other way to accomplish the above goals?
share|improve this question
up vote 11 down vote accepted
This is generally not a great idea. You're much better off making grab points for regular scope probes (making sure to provide nearby grab points for the ground clip, of course).
There are a number of problems, most of which you've actually considered - it's just that a direct coax connection is not the way to deal with them.
Here's your first problem. 30 MHz signals will suffer visible degradation if they feed lengths of coax, unless the coax is terminated. Your signals will propagate to the scope, be reflected, then reflected again and distort the scope signal, etc. While it's worth keeping in mind that regular scope probes use lossy coax, this is not something you'll use successfully without a good deal of theory.
Oh, absolutely. If you do, you'll get excellent signals at the scope. Ummm. Well, there is the small matter of driving the cable, of course. For 50 ohm cable you need to provide a source which can successfully drive 50 ohms. This rules out all "normal" op amps and all "normal" logic circuits. It implies a series of high-speed, high-power amplifiers on your board which are only used when you hook your scope to the board, and for most circuits will represent a considerable increase in power dissipation - so you'll need bigger power supplies. But go ahead, by all means.
Alas, no. While it's true that you could provide something like a 550/55 divider to produce a nominal 50 ohm source, when connected to a 50 ohm load you'd get about a divide by 20. Your circuit will see about 600 ohms loading, which is better than 50 ohms, but it's still outside the range most circuits are happy dealing with.
It's true that this works for divide by 10 probes, but only with lossy coax. You might be tempted try an unterminated coax, but this will have a considerable capacitance (typically 25 pf/ft for RG58, for instance) loading of the circuit.
The only "good" way to do what you want is, as I've mentioned, install a 50-ohm driver amp at every point you want to monitor, then terminate the cable at the scope with 50 ohms. And that's probably not very good.
share|improve this answer
It looks like you ended your fourth blockquote a little too late. – hobbs Feb 15 at 1:43
@hobbs - Yup. Fixed it. Thanks. – WhatRoughBeast Feb 15 at 1:45
A typical passive scope probe looks a bit like this (first google image search hit):
and every part in it is engineered well, often with decades of experience in mind. Certainly you can do your own probes, and it depends on what your actual goal is. See just something? Certainly possible, easy and cheap. Look out for Z0 probes for example. Have an idea of how the actual waveform looks like? This now gets incredibly much harder. The typical bandwidth of switchable probes in the 1X position is 5-8MHz and even the best engineering can't get this much higher, so will you be able with your home setup? Unlikely.
Here are just two examples of things done in modern high performance probes that are pretty hard to replicate at home, unless you buy the parts:
  • the probe cable is not strictly coax, its inner conductor is crinkled and it is lossy with a resistance of 100-200Ω per meter.
  • The platicy material between the tip and the ground ring is not only precisely manufactured to size, but is a material with a well controlled dielectric constant to keep the capacitance down.
Let me show you some google image search hit here again:
This is the impedance in Ohm vs. the frequency of the signal for three different probe tip capacitances. As you can see, even for the already very low 5pf you still have hundreds of Ohms of impedance instead of wanted Megaohms (There are probes with <1pf on the market, and their price is in the many thousands, and that has a reason). This response has to be flattened out to see proper waveforms.
For more information about scope probes in video form, I recommend:
Also a good read are these
tl;dr
Can you? Certainly with enough knowledge you can, but quite frankly, if you had that, you wouldn't be asking here, would you?
Should you? Most likely not, unless the only question you want to have answered is "Is there something" in which case a home brew Z0 probe is probably among the best. If you want some precision of the waveforms you have to properly characterize the probes frequency response and flatten it out so that there is no or minimal distortion in your waveform.
If on the other hand this is for playing and learning about how scope probes work, then this is a very good idea to do.
If the most thing you worry about is reachability and attachability of test points with low inductance paths, watch the Bob Pease video at around 8:00 in.
There are two basic types of passive probe, low impedance probes and high impedance probes.
Low impedance probes are used with the scope input set to 50 ohm mode and a 50 ohm coax line to the scope. You then have a series resistor at the tip to give your scale factor (i.e. 450 ohms for an x10 probe). The advantage of this setup is it's simple and it works well at high frequencies. It has these nice characteristics because it treats the cable as a proper transmission line feeding into a matched load. The downside is at low frequency it loads down the device under test more than a high impedance probe. Also some cheap scopes don't have a 50 ohm input option, you can use an external T-peice and terminator but it's not as good performance wise.
If your signals are large then you might want to consider making a 100x probe in this way. Less load on the circuit but obviously worse snr.
For high impedance probes you have the scope on 1 megohm input impedance. So your series resistor becomes 9 megohms for an x10 probe. However just having a resistor will result in a poorly behaved probe. To get a well-behaved probe you need to add a capacitor across your resistor that is 9 times smaller than the combined capacitance of your scope input and your coaxial cable (we are now treating the cable like a capacitor rather than treating it like a transmission line, this works ok as long as our cable is much shorter than the wavelength). Often a variable capacitor is used as predicting stray capacitance is difficult.
Physical construction of a high-performance passive probe is not easy because you will need to achieve extremely small parasitic capacitance in order for the voltage divider to work properly (produce a flat response) over a wide range of frequencies. Even the coaxial cable connecting the probe to the oscilloscope is difficult, if you give it any significant length. This makes it very challenging to build a passive probe that does not load the circuit strongly.
If this matters to you, then I propose that you attempt an active probe, for which you will be able to arrange 50 ohm output impedance for direct connection to the oscilloscope. You can find wideband FET-input opamps that have relatively small input capacitance, such as the THS4631, which has 1 GOhm || 3.9 pF input impedance. It should be more practical to make a wideband voltage divider local to the opamp than to construct a passive probe with only a few pF of capacitance.
The drawback is that this is not quite trivial either, and you might not want to treat such probes as disposable as the opamps do cost several dollars each, plus the cost of the PCBs. Here is a good example of a design by Rocketmagnet, which shows what could be involved. A single-ended probe can be a bit simpler, although depending on your requirements, you may still need more than one opamp. If you can get away with the bare minimum of one or two opamps and a voltage divider, then potentially you could construct it on a piece of copper-clad board and leave it attached the circuit to be probed. Whether this is worth the effort and cost every time is, of course, up to you.
discard
