Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I recently bought a lot of cheap CR2032 batteries from aliexpress. Since there is no manufacturer stated on the package or the batteries, I would like to know if these batteries really have 220 mAh or are they as fake as they are cheap. I would like to use them for a project with the bluetooth SoC nRF51822 QFAA, which draws 3 uA in sleep and few mA when radio is active.
I made a constant current load, to draw the constant current over time and to calculate the total capacity, but I was unable to determine the correct capacity because the voltage on the battery went down to 0.1 V and current from the battery to 10 mA. I used this schematic from instructables.
http://www.instructables.com/id/DIY-Constant-current-load/
I changed the resistor to 10 ohm (around 11) and the voltage on the pot to 0.5 V (not exactlly 0.5V). With these calculations, I should have gotten 45 to 50 mA constant current, but when i measured it, it was 37 mA (good enough). But after a while (no more that 30 minutes) the current dropped to 10 mA and voltage to 0.1 V. After disconnecting the battery the voltage slowly raised to about 3 V. The same happened with the Chinese batteries and with some of the known battery brands.
Is there any other way (or a better schematic) to test CR2032 battery capacity, without buying some kind of battery measuring equipment??
Why did the voltage drop? Was it because of the "high" current I was draining?
Thanks!
share|improve this question
You are drawing way too much current to get a meaningful capacity measurement. Set your constant-current load to 1 mA or so, and see whether the cell lasts ~200 hours. There's no way to do this "quickly". – Dave Tweed Feb 28 at 16:51
Compare to discharge curves on datasheets from a reputable manufacturer such as Panasonic. BTW, real, and fresh, Panasonic cells are only about 25 cents each in 100's. – Spehro Pefhany Feb 28 at 17:01
Just buy a BT-C3100 to test and charge all your batteries. You'll be happy you did. – fletom Mar 2 at 11:48
up vote 2 down vote accepted
CR2032 batteries are simply not intended for high current. They are lithium/MNO2 chemistry, which makes them lithium, not lithium-ion. For the behavior of a reputable source, see here, for instance where pulling a pulsed load of 23 mA produced about 1/2 volt drop in the output voltage. With that said, your nominal 37 mA isn't that much greater, so I'd expect something on the order of 5 hours duration for your test.
You need to test at much lower currents, like 1 mA max, and take your time. Your nominal 2200 mA-hr would last about 9 days at 1 mA, but even this is stressing the battery. From the web page, a 100 ohm load (about 3 mA) will pull down the battery voltage by half a volt in a few seconds.
EDIT - As Ecnerwal has pointed out, the battery was rated for 220 mA-hr, not 2200. My bad - brain fart. As a result, I'd expect something on the order of an hour or 2 for 37 mA, so low-current testing is still a good idea. At 1 mA, 220 mA-hr is 9 days, of course.
share|improve this answer
Thank you! Your answer was extremely helpful! – Lazyboy Feb 28 at 17:05
Factor of 10 issue with the capacity there. 220, not 2200. – Ecnerwal Feb 28 at 17:06
Yes plz I want all of these 2.2 Ah cr2032 – Passerby Feb 28 at 17:11
The problem with all of these answers is that they don't take one important fact about coin cells (all cells & batteries really) into account. That is that the capacity is nominal and wholly dependent on the load. A CR2032 is only 220 mAh when the load is small, 10k ohms or smaller. Maxwell's datasheet shows that a 300 ohm load, for a fraction of a second, every 5 seconds, will drop the capacity to 185 mAh, 18% decrease in capacity. Any large continuous load will decrease it more.
The only way to test is by following the same test conditions as the manufacturer or reliable source uses. In this case, 10~15kΩ, down to 2 Volts, which should be a few hundred hours for a nominal 220 mAh.
AA Alkaline Primary cells, or Li-Po secondary cells also have this, but at much higher loads and capacities, so its not as noticeable. Coin Cells like the CR2032, due to their much lower capacity and high ESR, must be loaded carefully to reach expected capacity goals.
As it happens, I had the same question, and since I also happened to buy an arduino-clone in the same order, I put them both to work to measure the battery.
Because I wanted a fair comparison, I searched in the datasheet from "reputable manufacturers" until I found one that had a discharge curve for a constant resistance, and one that did not take 500 hours. Eventually I found the datasheet for a SONY MicroBattery of the same size (CR1220 in my case). It has a discharge curve for a constant 10 kΩ resistance, which will discharge the battery in roughly 150 hours. I can wait for that.
SONY MicroBattery discharge curve
The Circuit
Then I needed to measure this accurately without excessive loading and keeping the parameters stable over time. I had a bunch of good old OP07 low-drift operational amplifiers at home, which I used for two things:
  • ADC reference voltage together with a reference voltage IC
  • Voltage buffer to decouple the ADC from the battery
I verified that the readings I got from the ADC into the log matched the voltage measured with external voltage meters.
The Data
After making sure all of this worked well and produced lots of nice data, I powered it up, let it heat up for a while, then connected a fresh battery and waited...
... and waited ...
... After about 200 hours the voltage was practically zero and I had 100 MB of text, which I filtered down, and then superimposed the data from the SONY datashet, the result is this graph: enter image description here
Conclusion
The cheap cell outlasted the expensive cell. Note carefully that my final graph is cut at the bottom, so the difference in voltage looks higher than it is.
Since chemistry isn't my thing, I can not explain the result, but as you can see, the steady-state voltage is roughly 0.1 volt lower than from the SONY datasheet, resulting in a slightly lower current drawn from the cell. This probably accounts for the longer life of the cell.
Going through the work of taking the data is a great exercise. If you ever decide to go even further with it, running a test (possibly side by side) with the documented cell could be interesting. But even more so, recording the temperature at which the test is run as that can have a significant effect on lithium capacities. Another question could be the accuracy of the resistor. – Chris Stratton Feb 28 at 21:12
@ChrisStratton Indeed, this was really just a "quick and dirty" exercise to see if it was even in the same ball park, and to see if I could get the "Arduino" up and running (first time I used any). I measured the resistor at 9969 ohm, but I don't have a calibrated instrument. – pipe Feb 28 at 21:22
For this type of battery the capacity is usually rated using a resistor in the 10k range.
The internal resistance is in the range of a few tens of ohm, therefore you experience a large voltage drop if the load resistor is too low.
Lithium coin cells are well known to have significant internal resistance, for one thing. This is why you can power most LEDs directly off a coin cell with no resistor and usually get away with it.
Discharging faster than the 20 hour rate will give you bogus (and low) results on almost any type of battery, for another.
What is the 20 hour rate? Nominal capacity (seems like 220 - 225 mAh is typical for 2032's) over 20 hours - or 11.25 mA, Max, in this case.
Given the usual type of service (low current) that coin cells are put to, the 100 hour rate might be more appropriate, or 2.2 mA - If what you are using them for needs more current, you might want a different kind of battery altogether.
Note that the rated capacity (240 mAh) from the Energizer datasheet linked by @WhatRoughBeast is rated at 0.19 mA (well, at 15K ohm load, and the current given at 2.9 V as the thing goes from over 3 down to 2 V.)
discard
