Tell me more ×
Given a board like this one with soldering pads but no traces, how would you connect adjacent components (including the ends of the jumpers for longer stretches)?
Some possibilities I've come up with:
  • Solder the individual leads as usual, then bridge the pads with solder.
  • For each connection wrap one of the leads around the adjacent component's lead before soldering the two pads (ensuring there's more than just solder joining the two components).
I started with the former before I came up with the latter (which seems like at least an improvement), but I'm wondering if there's some even better solution I haven't come up with yet.
share|improve this question
Here's another interesting method of perfboarding, this guy does it with SMD components and really tiny wires. He made a special little wiring pen for laying down the wires:
Progressive Wiring Techniques
example
Personally I make solder bridges for pins that are in adjacent holes, for things further away I use thin wires (though not as thin as the ones above) in adjacent holes to the things I want to connect.
Top of my board:
board top
Bottom of my board:
board bottom
And no, I didn't just wire those pins all on the fly, I had drawn up a detailed schematic in advance. There's no way I could keep track of so many wires just in my head.
share|improve this answer
The first cabling is outstanding :-) – Axeman Apr 14 '10 at 17:39
I have tried both the methods listed above, and I can certainly recommend the second one over the first. Trying to create solder bridges across the pads is not fun! The solder tends to blob onto the pads, and it does not like forming bridges. Heaven forbid if you have to make more than one bridge, then you end up creating one bridge, then destroying it as you try to create the second!
Perfboarding is an art, and requires a lot of thinking and forward planning to get neat. Never try to create solder bridges without something conductive in between. The best option is to use component leads to form the connections. Most through-hole components come with leads much longer than necessary, so you can use this to your advantage. If you need more material, you can use the snipped off ends of resistor legs, if you have them lying around. In addition, you can use hookup wire on the top of the board for longer connections. This is much less tedious than trying to carefully arrange multiple resistor legs along the bottom of the board, not to mention a better use of space.
If your circuit can be less compact, then you can use strip board (a.k.a. Veroboard) which has long continuous copper strips along the board. You can break the lines by grinding off the copper with a knife, scalpel or drill bit.
If you really want to be embarrassed about your perfboarding skills then look no further than: this. This guy knows the art!
Thanks Dave. That's good advice. It's nice to know I'm not totally out in the woods. – Lawrence Johnston Apr 13 '10 at 5:46
Your sentence about solder bridges made me laugh :-) Yes. IT IS FUN to make solder bridges... after some practice, you learn the correct timing, the correct temperature, the magic of a little blow on a bridge segment... it's an art :-) Some of my first prototypes also had DRAWINGS made with solder tracks. BTW: I can easily etch my own double sided PCB, but I like to build prototypes in this way also if I've already designed the PCB. – Axeman Apr 14 '10 at 18:07
I always bridge pads with solder, even for big circuits. It comes automatically after some practice.
These are two boards I've recently done (both of them deals with 220VAC)
alt text alt text
alt text alt text
I've built the second one directly from this breadboard version
alt text
My first realizations were more "fuzzy" ... this was a 8x8 led matrix I made more than 18 years ago, with NO MULTIPLEX: each led was directly connected to buffer output.
alt text alt text
And this is my most "knotty" array cabling:
alt text
(full size pictures are on this page)
  1. Take a length of wire-wrap wire (30ga or so).
  2. Strip end of wire long enough to bridge the two pads. This leaves a short length of stripped wire and the remaining insulation, which now ends at point X.
  3. Solder end of wire to one pad.
  4. Cut wire at point X.
  5. Solder point X to the other pad.
Wire wrap wire is perfect for this kind of thing. It is sometimes marketed as 'Kynar' wire. I can recommend it. – English Dave Apr 13 '10 at 21:49
discard
