Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
What is the main difference between and potentiometer, rheostat and a varistor? And how do the application of the three in a circuit differ? Or to be more concise, in a variable power supply why would you want to use each one rather than the others, or what benefits would one give over another in a variable power supply circuit.
share|improve this question
up vote 10 down vote accepted
A Varistor is a voltage-dependent-resistor. Its resistance depends on the voltage applied to it, and it is a 2-terminal device.
enter image description here or enter image description here
A Potentiometer is a fixed resistance with a mechanically adjustable wiper which can be moved from one end of the fixed resistance to the other, forming an adjustable voltage divider. It is a 3-terminal device.
A Rhoestat is not the same thing as a Potentiometer, since a Rheostat is typically considered to be mechanically variable resistor and is a 2-terminal device.
You can use a Potentiometer as a Rheostat by simply ignoring one of its fixed-resistor terminals.
The application in-circuit of a Varistor vs a Potentiometer is not really comparable as they are completely different devices.
share|improve this answer
Ok, thanks for your answer. Can you elaborate by referencing in what type of power circuit you would want to use each one and why. – RedDogAlpha Mar 9 at 19:14
My layman's understanding is that potentiometers are used in low-power applications - typically to control a signal amplitude. Conversely, rheostats are used in higher power applications to actually control power, e.g. a light dimmer switch. – Digital Trauma Mar 9 at 19:59
Calling a rheostat a potentiometer is pretty damn common, however. – hobbs Mar 9 at 23:13
@hobbs Probably because a potentiometer with one end disconnected is a rheostat. – immibis Mar 10 at 2:54
discard
