Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm looking at the Adafruit Feather 32u4 schematic.
power schematic
It auto-switches between battery and USB power. From looking at the schematic, when the USB power is not connected, the battery power VBAT goes through a MBR120 Shottky diode, then a SPX3819 regulator to power the Atmega32u4.
From looking at the datasheets, the MBR120 has a 0.45V drop, and the SPX3819 has a 0.25V dropout at 50mA. This would be a total voltage drop of 0.7V. Since the regulator outputs 3.3V, the minimum input voltage would have to be 4V.
Since a LiPo battery runs down to about 3.5V when getting low, that would mean that the circuit could not be powered except when the battery was very full.
Am I missing something, or is this how it works? It would seem strange that you would be unable to use most of the battery power.
share|improve this question
up vote 13 down vote accepted
You have to read the MBR120 datasheet carefully, that Vforward of 0.4 V is at 1 A. This circuit is not going to draw 1 A.
My guess is that it draws less than 100 mA, now let's look at the datasheet again.
At 25 Celcius Vforward is less than 0.2 V. Only under very cold conditions will it increase (but in the cold the battery will give up also so this is a moot point).
So this means that the minimum required Battery voltage will be around 3.3 + 0.25 + 0.2 = 3.75 V, a lot better than your 4.0 V.
Even if the battery is slightly below 3.75 V, it does not mean the circuit will stop working immediately. The regulated 3.3 V might drop a bit and that is no problem either as the Bluetooth module can work down to 1.8 V and the Atmega32 can work down to 2.7 V.
My guess is that the module will only stop working if the battery voltage drops below 3.3 V or so. And then the battery is empty.
Also, have a look at a discharge curve of a LiPo battery:
We discharge the battery slowly so we can use the black 0.2C curve. Note how you would have used 90% of the capacity if you would discharge to 3.6 V (which is a safe value).
So it all looks reasonable to me !
share|improve this answer
If you assume that the load is drawing only 100mA, then the dropout voltage for the regulator is lower as well. The SPX3819 datasheet has a chart that show dropout voltage vs load current. At 100mA, the dropout voltage is only 150mV. – JRE Mar 10 at 11:34
I was using the 0.25 V @ 50 mA as OP stated for the LDO. Obviously that number was also pessimistic. – FakeMoustache Mar 10 at 12:34
@JRE Thanks, I see that chart now. The 0.25V @ 50mA figure came from the "Electrical Specifications" table in the datasheet, and I now realize that was the max for over the full junction temp range (-40 to 125°C). I don't plan to run it at 125°C if I can avoid it! – localhost Mar 11 at 10:06
discard
