Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have just seen this integrator circuit here. As seen from the picture, there is a resistor at the positive input of the OpAmp. Could you explain what is the purpose of this resistor?
Integrator circuit
share|improve this question
up vote 18 down vote accepted
The resistor serves no purpose if the opamp were ideal. However, ideal opamps are hard to find. All the ones I've seen have some non-zero input bias current.
When the input bias current is significant relative to the external circuit, then having the same impedance drive both opamp inputs cancels out the offset voltage caused by the input bias current that is common to both inputs.
Bipolar input opamps have significant enough input bias current that it is usually specified broken down into the common and independent parts per input.
Modern CMOS input opamps have so little input current, and its polarity isn't predictable since it's due to leakage, that usually only its absolute value is specified. In that case, matching the impedances is less useful, and the worst case error from unmatched impedance is much less to begin with anyway.
share|improve this answer
Even bipolar input opamps employing current cancellation schemes (e.g., the OP27 is a classic of the sort) have an unpredictable polarity of the bias current. – Massimo Ortolano Mar 10 at 14:46
And don't forget auto-zero op amps. – dom0 Mar 10 at 18:28
discard
