Tell me more ×
Is Nios II required when implementing UART core using the SOPC? (or a default Nios is included) I tried writing my own module for the uart connection but it didn't work out. I need a method to connect a sensor to the de2, any method is fine. If you guys could give a clear method about how can this be implemented
This link gives an idea what could be done but its not that clear
I need a idea on how to go about it. With so many manuals and softwares available for the Altera..
share|improve this question
possible duplicate of De2 Board reading sensor reading – Brian Carlton Nov 17 '11 at 20:00
No. A UART is basically a state machine. Though if your data to be transmitted or received gets more complicated than you want to handle in a state machine, you might start to consider some sort of soft processor core. That said, while UARTs are very doable, SPI-type interfaces are simpler to implement, so if not dictated by what is on the other end, you might consider that. – Chris Stratton Jul 13 '12 at 14:31
1 Answer
The following links MAY be of use to you.
Zero guarantees.
DE2 Hyerterminal wannabe
RS232 from scales wannabe
UART / DE2 with links elsewhere
This looks useful Altera UART core overview. Chapter 8 in vaguely specified manual.
Do you have / are you using SOPC builder?
It SOUNDs to do what you want
  • The universal asynchronous receiver/transmitter core with Avalon® interface (UART core) implements a method to communicate serial character streams between an embedded system on an Altera® FPGA and an external device. The core implements the RS-232 protocol timing, and provides adjustable baud rate, parity, stop and data bits, and optional RTS/CTS flow control signals. The feature set is configurable, allowing designers to implement just the necessary functionality for a given system.
    The core provides a simple register-mapped Avalon Memory-Mapped (Avalon-MM) slave interface that allows Avalon-MM master peripherals (such as a Nios® II processor) to communicate with the core simply by reading and writing control and data registers.
    The UART core is SOPC Builder-ready and integrates easily into any SOPC Builder-generated system. This chapter contains the following sections:
    ■ “Functional Description” on page 8–2
    ■ “Device and Tools Support” on page 8–4
    ■ “Instantiating the Core in SOPC Builder” on page 8–4
    ■ “Hardware Simulation Considerations” on page 8–9
    ■ “Software Programming Model” on page 8–9
One level up above chapter plus many other modules
Using the DE2 JTAG UART about page 9 on.
share|improve this answer
lol. "zero guarantees". enjoy much your comments on links, lol. – abdullah kahraman Dec 16 '11 at 8:28
discard
