Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am a student of vehicle engineering and I love automotive electronics very much. Right now, I have an ESP sensor cluster to study, and I am lucky to have a look at the PCB inside. I have some questions about it.
First, why don't they use teardrops at the trace/via junction?
Second, why do they use only one trace to connect the resistor to the ground?
I am new here and my English is not so good.
share|improve this question
I think there's a little bit of a language translation issue here. In your first question, what do you mean by teardrop? – Dan Laks Mar 22 at 5:13
I cleaned up your question a bit. If I mistakenly altered the meaning of your question, please correct my edits! – uint128_t Mar 22 at 5:21
Thanks a lot.My English is not good at all.囧 – 梁政焘 Mar 22 at 5:23
up vote 6 down vote accepted
why they don't design the teardrop in the PCB?
Teardrops are used to reduce the chance of acid traps and perhaps reduce mechanical stress on the trace and via. However, they are not typically necessary. See "Why are there teardrops on PCB pads?" for a more in-depth discussion.
why they use only one trace connect to the ground?
I'm guessing you mean: why isn't the entire pad connected to the ground fill? This is called a "thermal", and it reduces the chance of uneven heating on the component during reflow, which can cause tombstoning. It also makes it easier to rework, should that be necessary.
share|improve this answer
But,why don't they use a "+"shape connect instead of "only one trace connect"? – 梁政焘 Mar 22 at 5:35
That's really up to the designer and the design software. The difference is insignificant. – uint128_t Mar 22 at 5:37
Maybe because of tombstoning.Thanks a lot and I feel shame for my English.T^T – 梁政焘 Mar 22 at 5:40
Usually, in very small components, you want each pad to have similar thermal resistance. One trace goes to the signal, therefore, one trace goes to ground. – Lior Bilia Mar 22 at 5:41
1) The fabrication processes do not explicitly require teardrops. We never design them in except if a customer explicitly wishes so. There is no real advantage to it unless you expect lots of mechanical or thermal stress on that via.
2) This looks like some kind of feedback network to me. There is no large current requirement here. If this was a Through-Hole Part, it would be done similar to this for thermal reasons. Parts can be desoldered/resoldered easier if the heat stays located in a small area than when you have to heat up the surrounding ground/power plane. I just wonder where the resistor at the very bottom is connected to.
It's interesting that they did not cover the Vias, maybe they use them as testpoints but I dislike this because the test may put additional stress on them. Better add dedicated testpoints.
The board is designed by Continental.In fact, they are professional in automotive electronics.They have tsetpoints in the board.I also doubt that why they did not cover the Vias.And I see many automotive electronics PCB without covering the Vias.There must be some reasons for this. – 梁政焘 Mar 22 at 5:47
There's little point in adding the extra + connections to the resistor, especially if there is little current through it.
Teardrops may not have been supported by their PCB design software. I use Eagle, and they are not available.
Thanks a lot!I use AD. – 梁政焘 Mar 22 at 10:51
discard
