I have checked sparkfun and some other websites. It seems that there is no air quality sensors available in the market.
I would like to monitor PM2.5 and PM10. Are there any suggestions?
I have checked sparkfun and some other websites. It seems that there is no air quality sensors available in the market. I would like to monitor PM2.5 and PM10. Are there any suggestions? | |||||
feedback
To detect dust, there is Sharp GP2Y1010AU0F, see http://www.watterott.com/de/Sharp-GP2Y1010AU0F-optischer-Staubsensor It is cheap, measures particulat matter in air by reflection. But it has a huge drift, and it is hard to interpret small readings, but it worked for me up to a point. It is also not particularly sensitive - a minimum of $0.1 mg / m^3 $ is quite a lot of dust. But for the price, it is certainly worth a try. And you must read the datasheet, of course. Problem is, if you measure around humans, the amount of big particle dust (the kind you see blinking in the sun) is abundant, and it becomes even harder to measure fine dust. To measure fine dust, which settles way slower than the big stuff, you will have to do a measurement while you are away. If you want to measure only the fine dust, you will have to filter that out first, and measure the particulate mass in the filtered air. That is probably not going to be cheap. | |||
feedback
I've used some gas sensors from Futurlec with some success - at the very least they are really easy to interface with. I don't know what PM2.5 or PM10 means, but here are a couple of links: | |||
feedback
It's a rather specialised field, as you know. Size selective inlet for manual separation. Calibration could be "interesting". No electronics here - but lots of scope for using them for control.
They say:
feedback
