Tell me more ×
Can someone help how to find formula and calculate this task?
How many times per second will be reset if the microcontroller is set to 1:128 preskaler microcontrollers and works on Frequency of 8 Mhz.
Could someone explain me how to solve this kind of task? Please.
share|improve this question
On the '887 you have 2 prescalers on the watchdog - the dedicated 16-bit watchdog prescaler, and the secondary prescaler shared with Timer0. Are you using the secondary one at all, or just the watchdog one? – Majenko Nov 30 '11 at 17:57
just watchdog one – jiki Nov 30 '11 at 18:00
1 Answer
The watchdog always runs from the internal 31KHz internal oscillator.
The general formula for calculating the watchdog time is:
\$\frac{1}{31000}\times WDTPrescaler [\times Prescaler]\$
Where \$WDTPrescaler\$ is the dedicated 16-bit watchdog prescaler, and \$Prescaler\$ is the optional 8-bit prescaler shared with the Timer0 module.
So in your case it's
\$\frac{1}{31000}\times 128 = 0.004129032\$
Which is roughly 4ms.
If you were using the secondary shared prescaler you would multiply the answer by that value as well.
share|improve this answer
if I use secondary prescaler the formula is the same or diffrent? – jiki Nov 30 '11 at 18:06
The formula would include the part in [ and ]. You can think of not using the Timer0 prescaler as using it but with it set to 1:1 - so multiply the answer by 1 - which does nothing ;) – Majenko Nov 30 '11 at 18:07
the value in [ ] is 128 or 256? – jiki Nov 30 '11 at 18:08
I have clarified my answer a little – Majenko Nov 30 '11 at 18:09
@jiki: Please accept the answer if you find it correct and helpful. – Andrejs Cainikovs Nov 30 '11 at 18:45
show 1 more comment
discard
