Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I want to switch an FTDI interface with a single mechanical switch towards two different endpoints. The FTDI interface has six lines, four two-way digital lines, plus power and ground.
My mechanical switch should be a single SPST or SPDT switch.
With relays, the answer would look like the schematics below. I would need six SPDT relays for that.
I would like to have a smaller solution, with a minimum of components and complexity. Voltage and currents of my circuit are low, about 3.3V and 10mA.
schematics
share|improve this question
like a cross port switch, as in any line can go to any other line? Or like a relay that you just want the electrical connect removed.... Also, they'll want to get specs voltage, current, etc... – kenny Dec 11 '11 at 12:46
Like a relay, each line has to be separate. I will add the information to the question. – henning77 Dec 11 '11 at 13:20
You need to be more specific. Are these signals or power? Analog or digital signals? – starblue Dec 11 '11 at 13:35
All lines are digital signals. – henning77 Dec 11 '11 at 13:38
Is there a specific reason, you don't want to use relays? Solid state relays are fast, low power and quiet. – 0x6d64 Dec 12 '11 at 7:32
up vote 2 down vote accepted
Use the switch to control analog switches. The switch then just needs to be SPST with a pullup resistor. This will be the control signal to the analog switches. One switch line can easily drive many CMOS inputs, so fanning out to six won't be a problem.
Analog switches are sometimes called "bilateral switch" because, unlike "digital muxes", they work just as well in both directions -- much like a relay. Sometimes I use an analog switch to connect the output of one chip to either one of two "input" lines (with pull-up or pull-down resistors to set the "other" line to the appropriate state), much like a digital demultiplexer. Sometimes I use an analog switch to connect the input of one chip to either one of two "output" lines (no resistors are needed for this case), much like a digital mux. Sometimes I use an analog switch to connect a bidirectional line like the I2C data line.
Analog switches act much like relays, except (a) they can't handle much current -- some handle 25 mA, others can handle only 10 mA. (b) they can handle only a limited voltage range -- some handle 0 to +15 V, others handle only 0 to +5 V. (c) they are lower cost, can switch far more rapidly and more often, and require much less power than relays.
(This is a minor tweak of the answer from Olin Lathrop).
Some parts I would consider:
  • 74HC4066 quad SPST bilateral analog switch
  • 4053 triple SPDT analog switch
  • 74HC4353 triple SPDT analog switch
  • 4052 dual SP4P analog switch
  • 74HC4852 dual SP4P analog switch
  • 14551 quad SPDT analog switch
You might be able to do this with two chips, and perhaps some pull-up or pull-down resistors.
share|improve this answer
I didn't know analog switches. Exactly what I need. Thanks! – henning77 Dec 13 '11 at 11:10
Use the switch to control digital muxes. The switch then just needs to be SPST with a pullup resistor. This will be the control signal to the muxes. One switch line can easily drive many CMOS inputs, so fanning out to six won't be a problem.
Can I also do it with a couple of simple transistors? These I have on my hand. – henning77 Dec 11 '11 at 14:09
Could you recommend a mux or range of muxes for the OP? – Majenko Dec 11 '11 at 14:10
How would the mux solution work? As far as I understand, a mux would have one output line. Wouldn't I need six muxes then? – henning77 Dec 11 '11 at 14:16
@henning: Yes, you would need six 2:1 muxes. However, you can often find multiple muxes with a common control input in the same chip. For example, the 74x158 is four 2:1 muxes in a 16 pin chip. You would need 1 1/2 of those. – Olin Lathrop Dec 11 '11 at 14:30
You might be able to do this with a couple of transistors (or, more likely, FETs), but we would need more info: what is connected to the inputs and outputs? (But the Muxes that Olin proposed are essentially a bunch of such FETs in a convenient package...) – Wouter van Ooijen Dec 11 '11 at 21:25
discard
