Tell me more ×
I am looking at SMD leds, and it seems that same leds of same color in 0603 and 1206 cases, having same rated current and same angle of irradiation, show different light flux, 1206 being several times brighter.
What is the explanation for this? My task is to get maximal brightness out of bunch of blue SMD leds. 0603 are smaller and cheaper, so for the same money I can place 3x times more of them, while 1206 have higher rated mcd flux.... Hi-power 1-3W leds which are rated in lumens does not work for me, as I would need them on flexible PCB.
I am puzzled... Any info on that?
share|improve this question
Can you please provide a few datasheet links to LEDs which are the same in 1206 and 0603 but have differnt flux. Also on what do you base the assessment of "same" - same part number, same binning, same ...? – Russell McMahon Dec 18 '11 at 11:45
Could it be that they are measured per pre-defined unit of area? So an LED a third the size will provide a third the light, but is the same rating as it covers a third of the area? – Majenko Dec 18 '11 at 16:30
up vote 4 down vote accepted
I think the problem is a lack of understanding of what one means by "brightness". Brightness is a very ambiguous term. First of all, I'll make the assumption that you are speaking in terms of a human's perception of brightness. This limits our discussion to photometry. You have to now differentiate between two measures of brightness, i.e. Luminous intensity and Luminous flux (or Luminous Power). Luminous flux is the light power emitted in all directions and has SI units of "Lumens". Luminous Intensity is the light power emitted in one solid angle which has SI units of "candela". Think of a solid angle as a cone with it's vertex at the led emitter. You mentioned mcd as units, these are millicandela, so mcd is a measure of Luminous Intensity. You can't directly compare luminous Intensity (candela)) with Luminous Flux (lumens). I did find this tool to convert between the two units, but, it must have to make the assumption that the light is omnidirectional and is only accurate for such lights.
You'll have to get your units straight before you can make sense out of this.
In additon, you have to decide what your objective is. Are you trying to make a light with high luminous Flux or one with high Luminous Intensity? I would imagine that you are going for a light with high luminous Flux or you probably would be speaking of laser diodes instead of LEDs.
So choose whatever package that maximizes your Luminous Flux, i.e. Lumens. You did not provide enough information to give a better recommendation than this. That is, you did not specify any additional design constraints.
share|improve this answer
It seems the issue was lack of such understanding by Chinese manufacturer. I've checked datasheets of reputable manufacturers, and flux is about the same for all chip leds. – BarsMonster Dec 19 '11 at 8:54
I believe the main difference is the optics.
A manufacturer may offer a chipled in 0603, 0805 and 1206 packages. The actual chip is the same, but the optics are different. Peak light output (luminous intensity) may vary but the total light output (luminous flux) is about the same. You should be able to see this if you look at the beam shape. You'll most likely also see a difference in half angle.
Assuming the distance from the emitting surface to the lens is the same for all packages, then if would be easier to shape the beam with a larger optic. If the manufacturer is weak on the optics you will have more losses and a wider beam angle with the smaller packages.
discard
